akumazedex Posted November 9, 2012 Report Share Posted November 9, 2012 Hey, I want to switch over to HEI on my 260z, I have a ZX L28E with a 260z Dizzy. Ive looked high and low for write-ups for HEI on a 260 with little help. Heres what ive figured out cross referencing 240 and 260 wiring diagrams, id like to know if i got this right. Sorry for the crappy diagram, im oldschool lol. Ive labled the wires on the coil/ign side the factory colors/codes that appear in the 260 wiring diagram. B-Black W-White L-Blue let me know if I got this right or if someone has a link to a write up thats not a 240z or 280z, Im retard when it comes to S30's LOL THANKS! AKUMA Quote Link to comment
datzenmike Posted November 9, 2012 Report Share Posted November 9, 2012 The HEI won't work on stock points dizzys. You need a magnetic pick up. You can use a remote igniter OR a matchbox dizzy for the HEI system. Quote Link to comment
akumazedex Posted November 9, 2012 Author Report Share Posted November 9, 2012 260z dizzys arent points type, it does have a pick up, since its the first Z with electronic ignition. The 260 dizzy issnt my problem, its the mess of wires on the ignition side, and since the 260 still uses a ballast resistor its confuzzling the eff out of me. Quote Link to comment
datzenmike Posted November 9, 2012 Report Share Posted November 9, 2012 That's right they all got early electronic ignitions. Well the right hand side appears to be wired correctly. The left side is just a coil of wire that has a small electric pulse induced by the stator. This trigger signal is sent to the HEI unit. There is no power sent to the distributor so nothing to burn out if wired 'backwards'. So hook it up if it doesn't work, swap the left side W and G wires. It will likely work either way. Quote Link to comment
re037 Posted February 17, 2013 Report Share Posted February 17, 2013 So after looking for days for more info on this, i cant seem to find a clear answer for my specific situation ***im keeping the stock coil and ballast resistor*** my transistor unit (ignition control module) went out and decided to repalce with a GM 4 pin hei. my ballast resistor is 3 pin insetad of 2 on a 240z. all the write ups refer to a msd or petronix coil and does away with the resistor ballast but no provision ive come across to keep the ballast on a 260z.heres the stock setup. and heres where i am right now in the diagram. Quote Link to comment
akumazedex Posted February 17, 2013 Author Report Share Posted February 17, 2013 There's a 4 pin connector that connects everything to the coil/ballast resistor. Two of those wires are power wires, one hot on crank one hot in run, you connect those two together and use that to power up the module. The black and green wires on the dizzy is your signal to the HEI. One positive one negative. Don't remember which ones which. And then the last one on the HEI is to the coil. I'll make a write up tomorrow when I get the tach sorted out. I completely got rid of the resistor but I think I need that to get signal to the tach. Like I said, I'll post a write up in my build thread tomorrow when I get it all figured out. :P Here's mine, I'll post up better pics too. Quote Link to comment
