sergent Posted November 6, 2012 Report Share Posted November 6, 2012 alright, I have a early 80s 5spd. took it apart, it went back together o.k. but is stuck in reverse while it should be in neutral. Other gears just stall motor without rocking forwars or rearward. Any ideas? :confused: Quote Link to comment
Stupid_fast Posted November 6, 2012 Report Share Posted November 6, 2012 you have to pull it out and remove the tailhousing the correctly align the shifter mechanism ... Quote Link to comment
sergent Posted November 7, 2012 Author Report Share Posted November 7, 2012 right on, I figured it out. you can actually kinda get to it if you remove the reverse check switch cylinder then reach in with a bent screwdriver. thanks for your reply Quote Link to comment
ggzilla Posted November 7, 2012 Report Share Posted November 7, 2012 So you are shifting by using a bent screwdriver? Or did you loosen the tail housing and reposition it? Quote Link to comment
sergent Posted November 8, 2012 Author Report Share Posted November 8, 2012 I repositioned it with a bent screwdriver> works perfect now! B) shifter now has control. Quote Link to comment
datzenmike Posted November 8, 2012 Report Share Posted November 8, 2012 Yes this would work, although I did not think of it. All you need to do is hold the shifter over towards 1st/2nd and that keeps the selector out of the way. Just reach in and 'flick' the shift rod back to the rear till it lines up. Ingenious! Quote Link to comment
