Bambino Posted November 5, 2012 Report Share Posted November 5, 2012 need help on fixing my 620.. not sure what's the problem, well I think it's the carb but not sure, I get spark, gas goes to the carb, it doesn't start, besides the fact of it starting up one time every morning.. I put new spark plugs, new distributor cap, and nothing, I looked to see the carburetor fuel level, and it showing like an 3/8s to being full... and it's leaking gas somewhere around the carb Quote Link to comment
Hermistonkilla Posted November 5, 2012 Report Share Posted November 5, 2012 Rebuild the carb and know for sure if that's it or not!! Or........ Check the floats first so you don't waste money if it could be a simple fix Quote Link to comment
ggzilla Posted November 5, 2012 Report Share Posted November 5, 2012 I'll be down in Astoria this weekend. I could come by Long Beach and look at it. What kind of leaking around the top of the carb? On a stock carb, only leak would affect power valve (not related to starting) or inlet valve, in which case the fuel bowl will be full. Do you mean there is some wetness there? Or gas pouring out? Quote Link to comment
Bambino Posted November 5, 2012 Author Report Share Posted November 5, 2012 yes decided to pull the float out.. it's running now, but seems like a lol less power makes different noise, and a lot of smoke is coming out of the exhaust Quote Link to comment
Bambino Posted November 5, 2012 Author Report Share Posted November 5, 2012 I'll be down in Astoria this weekend. I could come by Long Beach and look at it. What kind of leaking around the top of the carb? On a stock carb, only leak would affect power valve (not related to starting) or inlet valve, in which case the fuel bowl will be full. Do you mean there is some wetness there? Or gas pouring out? I can't tell where it is coming from exactly, but every time I start it I take a look and gas is around the carb, and yeah that be awesome if you can come by. Quote Link to comment
datsunaholic Posted November 5, 2012 Report Share Posted November 5, 2012 Pulling the float out would make it flood constantly since the bowl, which is supposed to be around 5/8th full, simply overflows. It'd be very smoky and low power since there's nothing to stop fuel from going in when the bowl is full, plus at idle it's be pouring out the top. Quote Link to comment
