Datsun random sale thread
I'll be adding new parts off and on !
Posting Datsun related items and non-Datsun related items.
PM/Email is best. Willing to ship some items.
Thanks for looking.
L28e Air Flow Meter (AFM) .. came off running driving zx .. worked good = $30
Engine compartment courtesy light = $10
Brand New catalytic converter .. 2.5" ? pipe (will verify) = $75
240z battery tray. Very light rust in a couple area's. Was drilled out and in very good shape. Bolt/weld/rivet on = $50
PM/Email is best. You can bump the thread as well
Thanks
Dtp
  • Replies 12
280zx Radiator. Goes in 240-260-280z for upgrade. No leaks and worked well. Came off a running/driving car. = $80
280zx heater/blower motor cage. =$40
1971 240z Gas Tank. Drain plug on bottom if you were not aware. = $100
Complete GOOD E88 260z head ("c" grind cam) = $100
Pressure tested N47 head that is flat = $100
280zx Air Conditioning compressor = $80
Subaru EJ22 Coil-pack. Works good. Was bought and used only to find out a shorting injector connector instead.
Was pulled off and stored. = $50
Carter Electric 280zx Fuel pump. Was new/newer last year. Worked well. Came out of a running driving/wrecked car.
= $50
280zx 2+2 Baffled E.F.I Fuel tank. Should be around 17 gallons. Worked good. I cleaned it out as best I could and worked well. Comes with entire Filler neck/cap/filler hose , and some other hoses. Great for zxt conversions. Metal breather tank available. = $100
  • 1 month later...
  • 1 month later...
  • 1 month later...
