Jon Rowe Posted October 27, 2012 Report Share Posted October 27, 2012 Im building a 510 race car here in the UK. The new diff mount rubbers I have are allowing the diff to move up and down by about 1/2 an inch, which in turn knocks out my camber settings. Should the mounting bracket be tight to the chassis when bolted up? Quote Link to comment
D52E Posted October 27, 2012 Report Share Posted October 27, 2012 Are you refering to the rear crossmember mounting points? I think the original mounting design did allow some movement for ride comfort. There are a couple of options to remove this loosenes. Some members do this Savage washer modification below to remove most of the slack. Other members run polyurethane or solid aluminum bushings. Solid bushings from Design products racing - http://dpracing.co/5...Suspension.html Savage washer modification - http://datsun510.com...arison&cat=3215 Quote Link to comment
Jon Rowe Posted October 27, 2012 Author Report Share Posted October 27, 2012 No....Ive sorted the crossmember bushing, its the diff mounting(the bracket that is bolted to the differential then in turn to the chassis). Quote Link to comment
Logical1 Posted October 27, 2012 Report Share Posted October 27, 2012 I'm guessing you mean the Mustache bar bushings? I looked into several diff bushing options (poly , rubber, ect.) I ended up making my own out of a blown tire I had using two hole saws. I traced the mustache bar washer out on a tire with a silver sharpy, cut the center hole out with a small hole saw bit and then cut the outer out with a larger bit to end up with a multi-layer rubber doughnut. They have been in for several years now and hold firm! Sorry for the crappy old cell pics: Quote Link to comment
Logical1 Posted October 27, 2012 Report Share Posted October 27, 2012 Found some newer pictures: Quote Link to comment
