supercrawler Posted October 24, 2012 Report Share Posted October 24, 2012 Anyone has a pic for L1600 timming mark aligner How it mount to the engine. Previous owner had removed marker. Quote Link to comment
alabama_lowlife Posted October 24, 2012 Report Share Posted October 24, 2012 I had the same problem a couple weeks ago. DanielC posted a pic http://community.ratsun.net/topic/48071-l16-timing-tab-location/ Quote Link to comment
supercrawler Posted October 24, 2012 Author Report Share Posted October 24, 2012 Thanks,, I bought this from E-bay,, Thought this is for L1600 engine. Pic posted from DanielIC that is what my engine marker has,, it doesn't look like factory timming marker, It's more like handmade. Quote Link to comment
datsunaholic Posted October 24, 2012 Report Share Posted October 24, 2012 That's a L20B one, or maybe NAPS-Z. Engines after 1974 or so use that type and ONE mark on the crank pulley, on the oil filter side of the block. Engines BEFORE 1975 use a single arrow, with multiple notches in the crank pulley, on the opposite (exhaust) side of the block. Least, that's how I remember it. Some late-model (late 70s/early 80s) import L16s and L18s use the later type timing marks, but the plate is still on the exhaust side. So, when crank pulleys get swapped from one to the other the marks don't line up at all. Quote Link to comment
banzai510(hainz) Posted October 24, 2012 Report Share Posted October 24, 2012 key is knowing what pulley you have on there. If a l16 pulley it should be pretty much as the photo or vid. You can see close enough thru the spark plug hole and the cam lobe positions to narrow down in the general area where TDC is and get the pointer or make on. That one you good is for the later L motors. I seen them on the left and right sides of the front cover. So the key is having the correct pully to match it. Most L16 pulleys have the 5 marks Quote Link to comment
supercrawler Posted October 24, 2012 Author Report Share Posted October 24, 2012 Thanks guys for inputs. Quote Link to comment
