pl521sss Posted October 24, 2012 Report Share Posted October 24, 2012 68 Fiveten heater valve Wanted Link to comment
datzenmike Posted October 24, 2012 Report Share Posted October 24, 2012 http://www.510coop.com/completed/heater.htm Link to comment
Silky_Johnson Posted October 24, 2012 Report Share Posted October 24, 2012 Do you want a "like new" functioning valve, or do you want one to rebuild (http://community.ratsun.net/topic/16631-stop-heater-valve-leak/)? I've got a couple in the garage, but I'm not sure what years I have. It does appear thought that, out of three, one is a little different. Does anyone know what distinguishes a '68 heater valve from any other? Link to comment
pl521sss Posted October 24, 2012 Author Report Share Posted October 24, 2012 Thanks Mike Will try this valve Looks the same as 68 http://www.510coop.c...eted/heater.htm Let me know what you have Might consider buying it also. Do you want a "like new" functioning valve, or do you want one to rebuild (http://community.rat...ter-valve-leak/)? I've got a couple in the garage, but I'm not sure what years I have. It does appear thought that, out of three, one is a little different. Does anyone know what distinguishes a '68 heater valve from any other? Link to comment
72240z Posted October 24, 2012 Report Share Posted October 24, 2012 Thanks Mike Will try this valve Looks the same as 68 Let me know what you have Might consider buying it also. You understand the 620 heater valve is only to steal the innards and rebuild the stock body right? Yours looks to be non rebuildable since the brass tabs are sheered off. You need to buy both the 620 valve AND a used stock core from silky for this to work. Link to comment
pl521sss Posted October 24, 2012 Author Report Share Posted October 24, 2012 I ordered the 620 valve Looking at the picture, I'm hoping the 620 valve is the same as 68' valve. (L shaped) So if I pry those tabs open and mount it on the 68' assembly, that should work. We will see You understand the 620 heater valve is only to steal the innards and rebuild the stock body right? Yours looks to be non rebuildable since the brass tabs are sheered off. You need to buy both the 620 valve AND a used stock core from silky for this to work. Link to comment
72240z Posted October 24, 2012 Report Share Posted October 24, 2012 Possible, good luck to ya. Idk about by you but the temps are def starting to dip here. Need to fix my blower... Link to comment
datzenmike Posted October 24, 2012 Report Share Posted October 24, 2012 By pass the valve altogether. Run the pipes from the engine to the core. Yes is will have no adjustment but it's winter. Fix it next spring. Link to comment
72240z Posted October 24, 2012 Report Share Posted October 24, 2012 By pass the valve altogether. Run the pipes from the engine to the core. Yes is will have no adjustment but it's winter. Fix it next spring. If its already cold there hell ya. If it happened to me in the winter it would be the 1st thing done lol. Link to comment
