sr71sss Posted June 9, 2008 Report Share Posted June 9, 2008 Looking for a automatic flexplate for a L20B engine, can't seem to find a decent one, the last one I pulled from the JY had the ring gear too damaged... willing to pay good money for one... Link to comment
datzenmike Posted June 9, 2008 Report Share Posted June 9, 2008 Pretty sure the flexplate from a Z20/22/24 and very possibly a KA24E will work as well. All have six bolt crank. The tranny bolt patterns are the same, though the L has a different tilt than the Zs and the KAs. I had a Z24 (truck) flex and it was identical to the L series flex. This will maybe give you more options. Link to comment
datsunaholic Posted June 9, 2008 Report Share Posted June 9, 2008 The ones from a L24 or L28 (810/Maxima and 280Z/ZX) will also work. Link to comment
datzenmike Posted June 9, 2008 Report Share Posted June 9, 2008 Actually that is the L flex plate I compared it too. An L24E with an L4W71B Link to comment
sr71sss Posted June 10, 2008 Author Report Share Posted June 10, 2008 thanks for all the tips guys I just got one today from a 1979 720 pickup with an L20B, motor had only 97K miles on it but after taking it apart I was shocked to see that it had 3mm of end play!!!!, The funny thing was that there were no spacer installed so I wascurious if I should use one as I pulled from a 720 eith the Z24 motor and it had a different flexplate and TQ conv with spacer installed?? conrad Link to comment
