flipsteresis Posted October 8, 2012 Report Share Posted October 8, 2012 I read in the forums about a 1994 Saturn bolt on replacement that can go directly to the battery one wire - (!) no drain when off - not spinning - 60A or better ( needed for trailer lights, etc...) alternator that can be made to bolt on to the spot where now resides my Hitachi crappy alternator in my 1983 Maxima wagon.. If anyone wants these old ones I have at least two - working but not strong enough at low idle etcetc..... Please give either info on how, or a source with the serpentine belt pulley replaced by a nice small v-belt pulley and necessary details to make a successful retrofit of this idea - after wrestling this for over a year - I am game to try this and cannot wait to put charging issues behind me... Also info on a kit for headlight relays and maybe even one for the windshield wipers .... Just think, I can bolt my battery down finally instead of having to switch it out when it dies - windows will go up and down faster, high beams... Ahhh... Dreaming.... If someone is just willing to hook me up that is nice too... peace, flipster Link to comment
flipsteresis Posted November 19, 2012 Author Report Share Posted November 19, 2012 Turns out ordering an alternator for a 85 firebird gives the poper AC delco .. Perfect alternator with great pulley - Problem: Does NOT fit Solution: make a bracket ! http://thenovelsound.org/83-Ratsun/alter-retrofit/ Link to comment
flipsteresis Posted November 19, 2012 Author Report Share Posted November 19, 2012 This is part of a whole project for the car I will have in the forum "projects" called "adding a trailer hitch to an 83 wagon" see you there - Link to comment
az_rat210 Posted November 21, 2012 Report Share Posted November 21, 2012 89-90 Maxima Alternator. 90 Amps, just have the pulley changed out from serpentine to standard pulley. Had my swapped out at an Alternator shop. Should be able to use the old standard belt pulley from one of the Hitachis. Note you may need the plug for that alternator, can also be gotten from alternator shop. Mine cost me $5.00, then just wired it into my B210, and its Internally Regulated like you Maxima should be. You may even already have the correct plug to the alternator as part of you wiring since its also a maxima. 1 Link to comment
ajen68510 Posted November 26, 2012 Report Share Posted November 26, 2012 This guy sells a 105amp for a Z car. I had to change the pulley, but works really well, specially if your running a big stereo and high powered lights . He has 2 versions 105 amp and 125amp. http://www.datsunstore.com/product_info.php/pName/125-amp-high-output-alternator Link to comment
banzai510(hainz) Posted November 27, 2012 Report Share Posted November 27, 2012 ajen68510 thats alot of money for a GM alternator that usually goes for half theat price. just ask them for the model number and we can make our own kits. THEY WONT TELL YOU Link to comment
ajen68510 Posted November 28, 2012 Report Share Posted November 28, 2012 ajen68510 thats alot of money for a GM alternator that usually goes for half theat price. just ask them for the model number and we can make our own kits. THEY WONT TELL YOU True it is. But it has a modified mount so it bolts right in.No, he won't tell u the model number,and i took it to alt repair guy and he said he could guess , but wan not sure , as the id badges internally had been removed. I would say he is very protective about the model he uses. I'm just saying its a alternative. I use one , and it works very well. Link to comment
banzai510(hainz) Posted November 28, 2012 Report Share Posted November 28, 2012 I do have one as well but all the numbers are gone. Its up in the rafters in the gagarge. Its a perfect fit.No funnky adjustmant brackets to make ect.. Got it for 50$ from Icehouse who got it from soembody else who was hurting for cash that paid 200$ Unfortunately I still use the old ext reg 50ampers and have about 3 new of those also.2 of which as Nisssan units Link to comment
flipsteresis Posted December 4, 2012 Author Report Share Posted December 4, 2012 Well, the thing does have an unusual mounting bracket fabricated for the purpose - but since we use the car and have to make the repair work on the spot I just decided to go with the bracket fabrication plan.. The 85' firebird alternator comes with the right pulley, costing a little more but saving a step ( about $75 ) I am sure I could have hunted harder for a proper fitting unit - but I decided to use what I got. As for the connector, It just needed a standard female blade connector. I soldered it for extra reliability and in case of heat, etc.. Definitely soldered the connector to the power out - That terminal can get hot if everything is on and running ( rain - wipers/ defroster/ high beams ) http://thenovelsound...alter-retrofit/ I seem to only have time to work on this on weekends with school and 2 jobs & a sick canine.. ;-( But the alternator and bracket seem to be working happily!!! Link to comment
AZhitman Posted December 7, 2012 Report Share Posted December 7, 2012 ALL my Datsuns get Saturn single-wire alternators. Bracket modification is simple, and you can buy the pulley from Summit for cheap. Link to comment
