Dawa Posted October 8, 2012 Report Share Posted October 8, 2012 currently: (with key turned to accessories OR engine running) all lights on, no sound, buttons dont do anything. constant power (yellow) to behind fuse panel with inline fuse switched ign power wired to actual 'radio' wire (blue/white) with inline fuse front speakers wired up (white/grey) rear speaker, power antenna, memory, illum, amp, dimmer not wired up ground (black) hooked up antenna wire plugged in history: bought the truck with all the wires a mess, all fuses pulled = no power to stereo today i finally cut a few feet of excess wire from everything, identified everything, installed fuses what could the problemo be? Quote Link to comment
DAT510 Posted October 8, 2012 Report Share Posted October 8, 2012 Take the face off and clean the contacts Quote Link to comment
Dawa Posted October 8, 2012 Author Report Share Posted October 8, 2012 thanks for your input. i took the face off and cleaned the contacts, as well as cleaned the contacts on the back where the harness plugs into but to no avail. also, it looks like the head unit is staying lit even after the key is turned to off. what do yall usually wire your ign power and constant power wires to Quote Link to comment
moparvwfreak Posted October 8, 2012 Report Share Posted October 8, 2012 on my 620s, the original radio wire works for the keyed ignition and then i run new wire to my aux fuse block under hood for the memory. seems to work pretty well for me. i also run new speaker wire, 14 gauge, to my speakers in teh kicks and rear pod speakers. sounds great in my trucks. as for everything staying on, looks as though the deck is shot. been there. time for a new one to me. Quote Link to comment
Dawa Posted October 9, 2012 Author Report Share Posted October 9, 2012 CASE CLOSED (CLOSE THREAD) well, it was probably the GD deck (had a date of 2000.) put in another deck i had and it worked perfect. guess i didnt fuck anything up after all ^^ CASE CLOSED (CLOSE THREAD) Quote Link to comment
moparvwfreak Posted October 10, 2012 Report Share Posted October 10, 2012 just because its 12 years old doesn't mean anything. the tape deck in my black 73 is from '94 and it works like a champ. Quote Link to comment
Dawa Posted October 10, 2012 Author Report Share Posted October 10, 2012 i agree but in this case i think in this case it mightve Quote Link to comment
moparvwfreak Posted October 10, 2012 Report Share Posted October 10, 2012 yeah, seems the case here. kinda sucks. had an old sony that finally died. kept eating CDs. Quote Link to comment
