TFM1066 Posted September 18, 2012 Report Share Posted September 18, 2012 Looking for the flex-plate register that pops on the back of the crank, any L-20B, L series 6 cylinder or Nap-Z motor with automatic trans, and 6 bolt crank. Any help would be great. 1 Link to comment
pl521sss Posted September 18, 2012 Report Share Posted September 18, 2012 I have one for 6 bolt crank. Anyone know if this is only needed for automatic transmission? Cause I disassembled L20B with 4 speed trans. I found that it's using that flex plate register also. Link to comment
TFM1066 Posted September 29, 2012 Author Report Share Posted September 29, 2012 bump, Link to comment
datzenmike Posted September 29, 2012 Report Share Posted September 29, 2012 I have one for 6 bolt crank. Anyone know if this is only needed for automatic transmission? Cause I disassembled L20B with 4 speed trans. I found that it's using that flex plate register also. It's only used on automatics. If there was one on a motor that had a 4 speed it shouldn't have been on there. It will space the flywheel back towards the transmission by about 1/8" and the starter will have trouble reaching in deep enough to engage the teeth. Link to comment
