280zx Steering knuckle balljoints?
SubwayGUY4
Alright i've searched and came up with some different answers everywhere.
I saw a picture of stock 510 steering knuckles with a ball joint and 280zx steering knuckles where the balljoint on the 280zx steering knuckle is slightly raised..which apparently puts it at a crazy angle where it will ripp a hole in the joint soon...
so my question is....with the later model 510 14mm ball joints.... Will that ball joint fit in the 280zx steering knuckle..instead of using the 280zx steering knucles with the 280zx ball joints....
or are they the same....etc etc...
thanks
  • 3 weeks later...
  • Replies 4
In the left side of picture below you can see a late 14mm 510 ball joint and 280ZX steering arm. The right side is 280ZX ball joint and 280ZX steering arm. I was not able to check the taper angle of the stud to confirm they are the same.
As you may see, the 510 ball joint and 280ZX steering arm combination results in pottential binding condition.
