76loooongbed Posted August 3, 2012 Report Share Posted August 3, 2012 Well here's the story........ I bought a 76 620 w/ auto trans that had been sitting for a while. Got it running with no problems. Drove it for a couple weeks and it drove great aside from having it rap out before it would shift. Vacuum line on the side of the trans causes this from what I've read. Then one day I'm driving it and it seems to jump out of gear and into nuetral. I don't feel or hear anything, but the rpms climb with no forward movement. I pull over and put it park and turn it off. After a minute or so I start it back up and it shifts into gear and I start to head home. Made it two blocks and it happens again, but this time it never goes back into gear. I check the fluid and it's nasty brown and purple and smells burnt. I chalk this up to the old trans just being on it's last leg and pull the old trans out. Got another one from a buddy that worked fine he just put a manual in his. I put the new one in along with a new filter and pan gasket. Fresh fluid as well. Also I blew out the lines and made sure nothing was clogged up. I fire the truck up and this one doesn't do anything either. It feels like it shifts fine and locks into park, but will not spin the drive shaft. I've tried everything I can think of with no luck. I put fluid in the torque converter when I put the trans in. I have triple checked everything from the flywheel to the torque converter to the input shaft, etc, etc. I'm out of ideas as well as patience at this point. Any ideas? I'm all ears. Thanks in advance. Quote Link to comment
datzenmike Posted August 3, 2012 Report Share Posted August 3, 2012 Warm it up and check the fluid level in park and engine running. Quote Link to comment
76loooongbed Posted August 3, 2012 Author Report Share Posted August 3, 2012 I checked it and it's just a hair under HI. Quote Link to comment
datzenmike Posted August 3, 2012 Report Share Posted August 3, 2012 Well you have nothing to loose so pull the right cooler hose from the tranny off the rad and have a pail handy to catch any fluid. Have someone start the truck. Does any fluid squirt out the line??? If not then the oil pump inside isn't working Quote Link to comment
76loooongbed Posted August 3, 2012 Author Report Share Posted August 3, 2012 I'll try that tomorrow after work and see what happens. Thanks. Quote Link to comment
datzenmike Posted August 3, 2012 Report Share Posted August 3, 2012 For the automatic to work it has to have hydraulic pressure from the oil pump. Left over oil from the pump is fed to some components to lube them but most goes through the torque converter to cool it and then on to the rad to cool the fluid. Quote Link to comment
76loooongbed Posted August 3, 2012 Author Report Share Posted August 3, 2012 Anything else you can think of to check if the pump is working? And when you say the right hose do you mean passenger side? Quote Link to comment
datzenmike Posted August 3, 2012 Report Share Posted August 3, 2012 Yeah, I think the pass side in the out from the tranny. No matter it will eithr come out the hose or out of the rad one way or the other. If circulating the pump is likely working. Quote Link to comment
76loooongbed Posted August 9, 2012 Author Report Share Posted August 9, 2012 Well, I had some time after work to finally get underneath the truck today. No fluid coming out of either hose. Pulled both off and blew out the lines and cooler again. Nothing clogging it up and nothing coming out still. So is there anything else it could be instead of the pump at this point? Did different years have a different length input shaft? Quote Link to comment
datzenmike Posted August 9, 2012 Report Share Posted August 9, 2012 Well if you swapped the tranny it's easy for this to fall out. It's the input shaft but I don't think it drives the pump. Quote Link to comment
76loooongbed Posted August 9, 2012 Author Report Share Posted August 9, 2012 What does it drive? The flywheel/torque converter is what spins the pump right? Quote Link to comment
datsunaholic Posted August 10, 2012 Report Share Posted August 10, 2012 Did you take the flexplate off? I put it on backwards once... no go. Quote Link to comment
76loooongbed Posted August 10, 2012 Author Report Share Posted August 10, 2012 I thought about that too and check it out. I couldn't get the bolts in if it was flipped around. They'd be too short. Quote Link to comment
datsunaholic Posted August 10, 2012 Report Share Posted August 10, 2012 I had no problem putting the bolts in with the flexplate backwards. It's just thin sheet metal that's been stamp-formed. It's just crankshaft flange + spacer + flexplate. Doesn't change the bolt length/fit at all. Quote Link to comment
datzenmike Posted August 10, 2012 Report Share Posted August 10, 2012 It's the same thickness if on backwards. Quote Link to comment
76loooongbed Posted August 10, 2012 Author Report Share Posted August 10, 2012 Hmmm It wouldn't spin if it was on backwards would it? Wouldn't the teeth be off? Quote Link to comment
datsunaholic Posted August 10, 2012 Report Share Posted August 10, 2012 The teeth will be a little off but not enough to prevent the starter from engaging, though mine was a little loud since it was grabbing teeth that had been worn the other way, and the backspacing wasn't right. What it does is sets the torque converter off by just a little bit, and the fluid flow passages then don't line up. Quote Link to comment
76loooongbed Posted August 10, 2012 Author Report Share Posted August 10, 2012 So if it was in backwards...I could have the plate off and still see it spinning? I wasn't sure it was in backwards or not, but I saw it was spinning and figured I had it right. Could this be my problem then? Also, there's a lip on one side of the plate. Should that lip be facing the rear or front side of the truck? Quote Link to comment
dropped620 Posted January 16, 2013 Report Share Posted January 16, 2013 did you say that you pulled a line off and started the truck and no fluid came out? Quote Link to comment
datzenmike Posted January 16, 2013 Report Share Posted January 16, 2013 Well, I had some time after work to finally get underneath the truck today. No fluid coming out of either hose. Quote Link to comment
dropped620 Posted January 30, 2013 Report Share Posted January 30, 2013 i work for a local tranny shop and if you started the truck and NO FLUID came out then the pump is bad. possible broken veins or pump gear internally. could have been caused by a stack convertor. That is only if you pulled the lines off the tranny and started it. Quote Link to comment
