NCLNDYM Posted July 31, 2012 Report Share Posted July 31, 2012 Anyone know where i can get a single master brake cylinder for my 72 510, running dual su's and need the clearance. Thanks for your help Quote Link to comment
ggzilla Posted July 31, 2012 Report Share Posted July 31, 2012 The 520 Pickup has a single of the same diameter (3/4"). http://www.rockauto.com/catalog/x,carcode,1211173,parttype,1836 And you'll have to Tee together all the brake lines. They are not as safe, so keep a good eye on the brake fluid. As always when swapping master cylinders, shims or spacer may be needed along with careful measuring of the pushrod. Quote Link to comment
NCLNDYM Posted August 1, 2012 Author Report Share Posted August 1, 2012 Thanks ggzilla. Will look into it. Quote Link to comment
MikeRL411 Posted August 1, 2012 Report Share Posted August 1, 2012 Per NISMO Motor Sports catalog you need: 16500-2200 SSS air cleaner assy. [which I asume you have or an equivalent] 16546-22000 Replacement element. [good luck] 46010-N0110 Single Brake Master Cylinder [that's the hard one] 46255-21005 Brake tube connector [to adapt the single outlet to the 2 ones you have] 47215-W6500 Master Vac Plate. Good luck, I know how you feel, it looks simpler than it turns out to be. If you can get the brake tube adapter, or have one fabricated, the whole world of substitution opens up to you. Quote Link to comment
NCLNDYM Posted August 1, 2012 Author Report Share Posted August 1, 2012 Thanks Mike, found your post a few days ago on google, just copied the numbers and then lost the page. What is a master vac plate, cant find any pics Quote Link to comment
MikeRL411 Posted August 1, 2012 Report Share Posted August 1, 2012 Thanks Mike, found your post a few days ago on google, just copied the numbers and then lost the page. What is a master vac plate, cant find any pics I have no idea what a "master vaccum Plate" is, I'm quoting the parts book. There's a Datsun parts manual included in an above posting [can't remeber which one] that has a 510 header. It might have a drawing of what it is. I don't have a 510 so only downloaded the 410 / 411 parts book. Quote Link to comment
ggzilla Posted August 1, 2012 Report Share Posted August 1, 2012 Master Vac is the brake booster. Quote Link to comment
