RB_Shaggs Posted April 24, 2007 Report Share Posted April 24, 2007 http://cgi.ebay.com/ebaymotors/Datsun-510-610-620-L16-Pistons_W0QQitemZ110117701436QQihZ001QQcategoryZ33623QQrdZ1QQcmdZViewItem pistons on ebay Link to comment
71-521 Posted April 24, 2007 Report Share Posted April 24, 2007 but standard size? are there any clean L16's that don't need to be bored out anymore? Link to comment
RB_Shaggs Posted April 24, 2007 Author Report Share Posted April 24, 2007 yeah i saw them on ebay when i was looking for weatherstripping and figured someone might want them.. Link to comment
datsunaholic Posted April 24, 2007 Report Share Posted April 24, 2007 I have a new set of flattop and a set of dometop L16 pistons, but like those above they're STD/STD. Finding a STD L16 isn't easy. And since I have about zero use for an L16, I wonder now why I bought them. What I need is a set of L20B STD pistons. Somehow I managed to lose ONE piston (and rod) from an L20B I took apart 14 years ago and just now want to reassemble. One piston is already in (from 14 years ago) but all I found were 2 more and the rod cap nuts for the 4th. I have a set of .040 over pistons, but I really want to use them in a block that needs that much overbore (040 is 1mm, basically they're 86mm pistons) Link to comment
71-521 Posted April 25, 2007 Report Share Posted April 25, 2007 you're finishing a motor from 14 years ago? now that's persistence! Link to comment
datsunaholic Posted April 25, 2007 Report Share Posted April 25, 2007 Persistance? More like procrastination. Doesn't help that I've lost parts, and had 2 engines in pieces at the same time. What was 2 separate piles in 1994 became several dozen small piles by 1999, and wasn't touched until a month ago when all the little piles became one big pile. But I'm still shy one piston/rod assembly. And it's not like I can look for it every night, because this stuff is in my folk's garage, which is nearly as bad as my garage. My folks (well, my Dad) want their garage back, and it'd be a heck of a lot easier to get the car in there out if I were to reassemble it there rather than try to haul it out in pieces to reassemble here (I didn't just take the engine apart- I took the whole damn car apart). Link to comment
hang_510 Posted April 25, 2007 Report Share Posted April 25, 2007 i have a set of std L20b Arias forged, domed pistons avail, w/ pins & rings. if you wanna go high compression. Link to comment
datsunaholic Posted April 25, 2007 Report Share Posted April 25, 2007 Nah, already saw what Z20S flattops with a L-series heads does. I may get another engine for parts- someone offered me 2 complete (but one is completely apart) L20Bs with a lot of new parts in boxes, clutches, extra heads, etc. That is if he responds back. I wouldn't be going through all this if I could find a NAPS-Z dogleg, but so far I have yet to find ONE in a wrecker. They're awful rare. Have plenty of L-series doglegs (2 or 3) and NAPS-Z 63L 4-speeds, but no NAPS-Z doglegs. Link to comment
slodat Posted April 25, 2007 Report Share Posted April 25, 2007 What about the 4x4 5 speed that is the short shaft out of the '83-'84 4x4's? Link to comment
datsunaholic Posted April 25, 2007 Report Share Posted April 25, 2007 Not sure about that one- main problem is it has no speedometer output (the speedo output was on the T-case on those), and I really kinda want the speedo to work. Plus I'm not 100% sure it's the same length, and being a non-welder I am pretty much limited to what bolts in. I need engines for 2 '78 510s. I have one NAPS-Z that would drop in, but it has a 4-speed on the end and I'd much rather a 5-speed. The longtail won't work in these- I'd have to remove the console and relocate the parking brake. That'd work for one, but I'd still need to build an engine for the second. I may just drop the NAPS-Z in my '78 Wagon with the 4-speed as-is, it would require some wiring mods and a new throttle cable (both because of the opposite side intake) but that's about it, and build up the L20B for the hatchback. Dunno. Link to comment
slodat Posted April 25, 2007 Report Share Posted April 25, 2007 You could put a NapsZ front half on an L series dogleg and you would be golden! Link to comment
datsunaholic Posted April 25, 2007 Report Share Posted April 25, 2007 Yeah. If I had one. Problem is I need the NAPS-Z front half. The FS5W63A has a unique front half, so you can't use the one from a different model. Link to comment
