L engine coupled with R4W63 transmission, posible???
JP521
Hi!Im thinking about to get a L engine, pointing to a L20B in the best case, but if i get a L16 or L18 will be OK. But this is the problem, is posible to couple the R4W63 transmission that come with the J13 engine to any of these engines? or should i necessarily put the transmission "F4W63" if i'm not mistaken? But I want to keep the columm shift thats sure. Thanks!!!
  • Replies 6
the J motor has a different bell housing.. the l-series is going to need the F4w63 or other l-series trans.
you might be able to fashion some sort adapter plate so you can retain the stock trans with the column shift when you go to the L motor.
