Lockleaf Posted June 13, 2012 Report Share Posted June 13, 2012 1985 720 with Z24, running Weber DGEV 32/36. I am pretty sure that my jetting/venturis are wrong. the truck runs ok but I am pretty sure it is running very rich and I can tell that it is outside the normal range for tuning out just with the carb. I was wondering if any of you guys know which venturis/jets you are runnning and seeing good results from. Or if any of you bought a brand new redline kit, what sizes did it come from them with? Any help would be appreciated. I have not yet removed my carb, so I don't know the numbers on the settings I currently have. Quote Link to comment
ggzilla Posted June 14, 2012 Report Share Posted June 14, 2012 You cannot replace the venturis on a Weber 32/36, they are cast in place. This means you can't fit larger venturis for the 2.4 liter. But the 32/36 flows nearly as much air as the stocker Z24 carburetor, so no worries. Here is what Weber recommends as a baseline for the Z24: Main Venturi: 26/27 Aux Venturi: 3.5/3.5 Main Jet: 140/135 Em Tube: F50/F6 Air Corr Jet: 165/160 Idle Jet: 55/50 Pump Jet: 50 Needle Valve: 2.00 1 Quote Link to comment
Lockleaf Posted June 14, 2012 Author Report Share Posted June 14, 2012 Awesome. Thank you. That is exactly what i needed. Now gotta tear off the carb and see whats up. Quote Link to comment
