fiveonezero Posted June 6, 2012 Report Share Posted June 6, 2012 Are custom length axles needed for a 510 with a s13 complete rear suspension swap? Quote Link to comment
fiveonezero Posted June 17, 2012 Author Report Share Posted June 17, 2012 hummm ok so i guess nobody knows Quote Link to comment
TENDRIL Posted June 17, 2012 Report Share Posted June 17, 2012 i am not sure if this has been covered on here yet, but be patient buddy someone will help if they can. welcome to ratsun Quote Link to comment
Laecaon Posted June 17, 2012 Report Share Posted June 17, 2012 Well the S13 rear end is a lot wider than the 510. If you are planning to swap the entire rear end in, you will need to shorten axles, and bring the mounting for the arms inboard/change the length of the arms. Quote Link to comment
fiveonezero Posted June 20, 2012 Author Report Share Posted June 20, 2012 yea the subframe has already been narrowed and installed with a rear tube chassis as well and im using the s13 diff so i was thinking the axles would have to be shorter but just wasnt positive..i havent found much info on this swap yet but still searching...thanks for any advice Quote Link to comment
INDY510 Posted June 20, 2012 Report Share Posted June 20, 2012 yea the subframe has already been narrowed Pics? and installed with a rear tube chassis as well and im using the s13 diff Pics? .. :lol: ... or some sort of an explanation of what points are strong enough to support a rear tube chassis?? . or is it a full roll cage? .. .. why wouldn't you need shorter axles? Quote Link to comment
sssr20det510 Posted June 20, 2012 Report Share Posted June 20, 2012 http://www.the510realm.com/viewtopic.php?f=29&t=15741 Quote Link to comment
fiveonezero Posted June 21, 2012 Author Report Share Posted June 21, 2012 good point INDY510... Quote Link to comment
