wpg_wild_cat Posted May 22, 2012 Report Share Posted May 22, 2012 What transmissions are compatable with a 1973 620 2wd. Right now it has the F4W63 4speed. D Quote Link to comment
datzenmike Posted May 22, 2012 Report Share Posted May 22, 2012 The transmission from a 510 wagon is an almost exact match for gearing the 510 sedan is next. The 710 and the A10 (HL510) 4 speeds will also fit. If you should decide that you want a 5 speed an FS5W63 from a '77-'79 S10 (200sx) is a good fit for length. You will have to modify the rear transmission mount but can use your current clutch and flywheel. Quote Link to comment
ggzilla Posted May 22, 2012 Report Share Posted May 22, 2012 Don't forget that 1972-1973 Datsun 620 4-speeds fit too. Quote Link to comment
