hitch Posted May 21, 2012 Report Share Posted May 21, 2012 Do I pry at A or B Do the bolts C need to be removed? Once again, pry the axel at the housing cover or on the housing sub assembly? A Or B ? I need to get the boots replaced on this axle, and the FSM just says "Extract drive shaft from differential carrier by prying it with a suitable steel bar. Car is 1983 maxima Quote Link to comment
hitch Posted May 21, 2012 Author Report Share Posted May 21, 2012 Mike, B in the picture or the line drawing? Sorry, I should have checked my labeling. Quote Link to comment
datzenmike Posted May 21, 2012 Report Share Posted May 21, 2012 I removed an R-200 once and the axles just pop out. Used a pry bar and just inserted at B above between the turning part of the half shaft and the flange on the diff with the four small "C" bolts on it. A quick snap of the wrist and out she comes. Might be wise to drain first or you'll look like a porn star. Quote Link to comment
hitch Posted May 23, 2012 Author Report Share Posted May 23, 2012 I want to thank Mike, for the useful assistance in removing the axle's. I used the large screwdriver to move the axle just slightly away from the differential. Then used my pry bar to extract the axle. It took quite a bit of force to extract it. I was going to replace the boots myself, but due to a large list of honeydoos this week, I'm using a local rebuilder. They quoted me $110 each and about 2hour turn around. This would be much easier with a lift, but the jack stand on your back method worked for me. I'll show a picture of the pry bar and extracted axle's for your viewing pleasure. See the busted boot, grease inside was clean End of axle shows no signs of wear, good! I put the manual there to give a reference of the pry bar size While there, I replaced a damaged stud that had been cross threaded at some time past. Quote Link to comment
hitch Posted May 24, 2012 Author Report Share Posted May 24, 2012 Here are the completed Remanufactured axles, all done in about 3 hours. Total price for both was $147 and the came with a 2 year 24k mile warranty. Seems like they did a really nice job and the price was very good. I don't think parts other than new boots were required, but they cleaned and inspected all bearing surfaces. The name of the company that did the work is (CV Source, Bufford, GA) 1 Quote Link to comment
flipsteresis Posted December 24, 2012 Report Share Posted December 24, 2012 I am geting our driveshaft balanced and repaired for towing - will post pix - etc. soon! Quote Link to comment
