onefine,fivedime Posted May 10, 2012 Report Share Posted May 10, 2012 hows it goin guys, sorry i didnt look around first but im really trying to fix this issue before saturday so i can drift at the k.r.o.p.s. event at adams kart track. well a week ago i lost all my gauges on the fwy and stopped off at an autozone. my dime is a 72 by the way, and has a single cam swap but with all the stock wiring still intact (wanted to make sure it all worked before cutting stuff out) and the flasher fuse was blown. replaced it, blew as soon as i turned the key. an hour earlier i had moved the wiring that runs across the bottom of the core support ( ign coil and d/s light wiring) but just off the holder tabs and back on, nothing crazy. when it pops i lose temp and fuel gauges, turnsignals and emergency flashers, charge,oil, and park brake lights... it doesnt always blow it right away, but where i have it parked right now it does.... wiring coming through firewall is unchaffed... ive looked under the dash and all connections are tight and undamaged... all plugs coming in from engine bay are also fine... i have not taken apart the column cover, but dont feel its anything in there.. . electrical is not my friend. .. my next step is to unwrap the 40 year old wiring in the engine bay and check every wire individually =( .. anyone had similar issue or know where i should check instead? thanks for your help guys! Quote Link to comment
banzai510(hainz) Posted May 10, 2012 Report Share Posted May 10, 2012 how about pull the flasher can then put the fuse back in and see if pops with out the can installed. Possible bad flasher can Quote Link to comment
datsunaholic Posted May 10, 2012 Report Share Posted May 10, 2012 Check the reverse light wiring to the transmission. If it blows the instant you turn on the key, it's something that's powered when the key is ON. One of the 2 reverse light wires is always live, and the wires tend to snag stuff that hangs low. 1 Quote Link to comment
onefine,fivedime Posted May 11, 2012 Author Report Share Posted May 11, 2012 Banzai: i have tried it with the turn signal flasher. A couple times already.... but i havent even tried it with the four way flasher come to think of it. Datsunholic: im gona have to check that as well! Thanks! Will update in a bit Quote Link to comment
onefine,fivedime Posted May 11, 2012 Author Report Share Posted May 11, 2012 Datsunaholic: you just fixed my car from way the fuck over there!!! Thank you! =D jacked the car up and got underneath, found the connector to the reverse light switch in side my x member w a wire frayed! Pulled it outout and put in a new Sure enough, worked. Great! Just to confirm i put the wires. To ground and bam! Popped the fuse Quote Link to comment
datsunaholic Posted May 11, 2012 Report Share Posted May 11, 2012 You want to know why that idea was so fresh on my mind? I had the same problem last month. Glad you found it. 1 Quote Link to comment
