DADZSUN Posted May 8, 2012 Report Share Posted May 8, 2012 I just complete the Dogleg swap this past weekend and the starter bolts are different than the OEM 510. The 510's starter mounts are right through the bell housing and fastened with a bolt & nut, the Dogleg has the threading in the bell housing. - I've tried the usual Datsun bolts but they all seem to be slightly too small in diameter. - I tried Nissan, and they've identified it as PN 23480M4900. However, it"s not in stock and they want $14 each! - I tried online and the price is more reasonable but shipping is $20+. Any chance one of you guys have a spare set I can purchase? thanks Link to comment
Laecaon Posted May 8, 2012 Report Share Posted May 8, 2012 Hardware store. I want to say M10x1.5 (same as tranny to engine bolts.) Link to comment
datzenmike Posted May 8, 2012 Report Share Posted May 8, 2012 Canada is full metric. Go down to Crappy Tire and try some to find one that fits. Link to comment
DADZSUN Posted May 9, 2012 Author Report Share Posted May 9, 2012 Thanks for the info guys. It's not the same as a tranny bolt because when I tried it there was still some play in both the top and bottom mounts. It's almost like the tranny bolt are 1/4 mm too narrow. I've thought of Crappy Tire, but I don't want to experiment with different bolts and potentially strip the threads within the bell housing. Surely someone has a spare set somewhere or on a junker? Link to comment
datzenmike Posted May 9, 2012 Report Share Posted May 9, 2012 Just screw in by hand. It will either fit or not. Link to comment
Laecaon Posted May 10, 2012 Report Share Posted May 10, 2012 Really? Because that is how my dogleg is... My spare headbolts (M10x1.5) screw into the block, and they screw into the starter mounts. I really doubt anyone would have these bolts separate. try an assortment of bolts. It will be metric unless someone retapped it (that would be a nightmare). Link to comment
datzenmike Posted May 10, 2012 Report Share Posted May 10, 2012 Maybe they have already been stripped and drilled and re-tapped to a different bolt. maybe not even metric. Link to comment
Boaty Posted May 10, 2012 Report Share Posted May 10, 2012 I'm with Mike on that. All the transmission bolts should be the same size, including the start bolts. MAY be a different length. FWIW I used tranny bolts for starter bolts on my L16. And I used tranny bolts for the starter on my L20B, one was a little longer though. If they are a different SIZE, then it's been drilled and tapped. Pretty sure all trans bolts are M10. Link to comment
Laecaon Posted May 10, 2012 Report Share Posted May 10, 2012 Ah no one reads what I type! :frantics: Link to comment
datzenmike Posted May 10, 2012 Report Share Posted May 10, 2012 . It will be metric unless someone retapped it (that would be a nightmare). You get the credit.... :thumbup: 2 Link to comment
Laecaon Posted May 10, 2012 Report Share Posted May 10, 2012 You get the credit.... :thumbup: Haha, I just kinda felt like my posts were invisible... that is all. Link to comment
Boaty Posted May 14, 2012 Report Share Posted May 14, 2012 Did you hear something? o.O Link to comment
