Jayden71 Posted April 8, 2012 Report Share Posted April 8, 2012 You mean Z22?? :confused: Link to comment
datzenmike Posted April 8, 2012 Report Share Posted April 8, 2012 You mean Z22?? :confused: Yeah, that's what he said. Z22 crankshaft. Why? Link to comment
Jayden71 Posted April 8, 2012 Report Share Posted April 8, 2012 coulda swore it said L22 Link to comment
Danny Posted April 8, 2012 Author Report Share Posted April 8, 2012 It did I fixed it it thanks. Link to comment
Danny Posted April 8, 2012 Author Report Share Posted April 8, 2012 Making a stroker motor. Link to comment
510rob Posted April 9, 2012 Report Share Posted April 9, 2012 Rock Auto --> Nissan --> 1982 --> 200SX --> Engine --> Crankshaft --> $165 with bearings??? --> Win? www.rockauto.com Link to comment
datzenmike Posted April 9, 2012 Report Share Posted April 9, 2012 12201-06W80 for the '81-'82 720 Z22S.... $750.00 12201-06W01 for the '83-'83 200sx. Z22E Link to comment
Danny Posted April 9, 2012 Author Report Share Posted April 9, 2012 Mike, What is the differences and witch one will make a better stroker? Link to comment
ryknot Posted April 10, 2012 Report Share Posted April 10, 2012 Theres one on Ebay . .. . http://www.ebay.com/itm/Nissan-Datsun-Z22-Stroker-crankshaft-L20B-510-610-620-720-M90-90-/130678722194?hash=item1e6d0f0e92&item=130678722194&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr Link to comment
datzenmike Posted April 10, 2012 Report Share Posted April 10, 2012 Mike, What is the differences and witch one will make a better stroker? I don't imagine they are any better than the other. Link to comment
sam Posted April 11, 2012 Report Share Posted April 11, 2012 wait i can put a z22 crank on my l20b and it makes it a good stroke Link to comment
datzenmike Posted April 11, 2012 Report Share Posted April 11, 2012 There are several ways to do this. If you have a good running Z22 just put the L20B head, timing cover & chain, oil pan, dizzy and the metal brackets that go between the block and the rubber mounts. Optional... move the Z22 dipstick from the driver's side to beside the starter. Or check oil when the motor is cold. Compression will be 9.84 with an open chamber head. If you have a Z22 crank with the rods and pistons attached and an L20B block just bore the cylinders out to match the Z22's 87mm piston size. Install the crank and the pistons and rods.... nothing else needed. Same compression as above. If all you have is the Z22 crank and pistons you can use your L20B rods and every thing is the same as above. Same compression as above. Link to comment
sam Posted April 11, 2012 Report Share Posted April 11, 2012 so what kinda of power gain am i getting lol like 15% more ? Link to comment
datzenmike Posted April 11, 2012 Report Share Posted April 11, 2012 Well roughly a 10% increase in displacement so ... 10% at least. Nicer low mid torque, so it will feel like more at the speeds you drive 99.9% of the time. Each point of compression increases the efficiency and nets roughly a 4% increase in power so 8.5 to 9.8 is about 1.5 x 4% or 6% of say 110hp makes it 116hp. This is conservative. Link to comment
DADZSUN Posted May 20, 2012 Report Share Posted May 20, 2012 Well roughly a 10% increase in displacement so ... 10% at least. Nicer low mid torque, so it will feel like more at the speeds you drive 99.9% of the time. Each point of compression increases the efficiency and nets roughly a 4% increase in power so 8.5 to 9.8 is about 1.5 x 4% or 6% of say 110hp makes it 116hp. This is conservative. Not to hijack but it's along the same topic: So I'm running an L16 with 8.5 compression ratio (I think) and I'm digging not having to cough out for premium gas. I've got an L20B with W58 head that was supposedly rebuilt by the PO but not installed. I'm not sure if the rebuild actually occured or what quality is was done, also the head has been left open to dust & grime. I think I'd rather tear it down and rebuild than risk putting something in the car which might cr@p out in the middle of nowhere etc... The Z22 crank and pistons in a bored L20B sound great for an LZ22, but what's the resulting compression ratio? ~ mid to high 9? What can I do to get to sub 9 and once again return to regular gas? Is it even worth the cost of crank/pistons/bore to gain that 10% increase? Thanks! Link to comment
datzenmike Posted May 20, 2012 Report Share Posted May 20, 2012 If you use 87mm stock Z22 pistons your compression will be 9.8 if used with a W-58 head. (assuming it was not milled down) I would install it and see if it was rebuilt or a smoker. If it runs good run with it. An L20B will knock your socks off if you are used to L16 power. Link to comment
