bosifus Posted April 1, 2012 Report Share Posted April 1, 2012 I was messing around today trying to think of a way to fix the rear pop out window on the drivers side of my 210 that has been broke since I got the car. I have two kids so I'll never hear the end of it if ONE has a functioning "cool" window. Anyway, there is a small plastic piece inside the latch that acts as a lever when opening the window that was broken on mine. The window would flop around pretty good or pop open when shutting a door. My daughter and I used some fencing wire to replace the plastic link piece and it works great, I had to drift out the pin holding the latch to the bracket and flair the end of it open a little bit when re installing it to keep the wire from sliding off with extended use. All in all it took me maybe and hour using a pair of needle nose vise grips, a drift, hammer and vise. The window functions perfect now and it was an easy fix. When the latch is closed you can't see the wire at all. Anyway I thought I'd throw it out there for anyone else needing the fix. Oh and its galvanized too! lol Quote Link to comment
420n620 Posted April 1, 2012 Report Share Posted April 1, 2012 I'll be at a P&S tomorrow and so happens they have a 79 210. If you can confirm this is the same 310 as yours (HLB310), I'll pick that part up, if it's not broken, of course. Quote Link to comment
Sealik Posted April 1, 2012 Report Share Posted April 1, 2012 From what I can see.....it looks very similar to the latches used on the 720 KC Quote Link to comment
