Stock l20 carb acting up....
Right now my truck idles at about 1800rpm so I dont have to three petal it to drive. Great on short trips, not too worried about gas. But after a hiway run and full temp, itll idle high and then start dropping off, eventually sputter and die. then I have to crank the shit out of it to get it to start again. I dont have much carb experience (always thrown on whatever weber I could and made do) but I want this thing to purr. And under 1000 rpm. Im throwing in a rebuild kit when I get a chance, but is there anything I can do in the meantime, or anything that comes to mind I should look for when I do the rebuild?
  • Replies 4
always thrown on whatever weber I could and made do)????????????????
so is there a weber or stock carb on there now.
stock carbs have the idle cuff off circut
makse sure your timmed correct and see if the 2nd barrel is fully closed. a stock hitachi uses vacuum so just make sure the 2nd barrel isnt jamming up and not closeing. If not closeing then it will act like its running higher.
