that one guy Posted March 30, 2012 Report Share Posted March 30, 2012 Can anyone help me to find a set of rims, 15 inch, for under $150? That's all I need to get this project off the ground... They're going on a 280z so the lug pattern is 4x114.3 I really don't care what they look like, as long as they're 195 to 215 wide. Thanks all! Quote Link to comment
HRH Posted March 30, 2012 Report Share Posted March 30, 2012 Since you used punctuation, I'm going to be nice. However, your first post should not be in the general section when there is a for sale section. Namely "Parts Wanted." Second, you need to research rim widths. You're probably looking for a 6-7" wide rim. Tires are measured in mm, rims aren't. 15" rims in that bolt pattern are not very common. Especially not very common for under $150. I'd advise getting 14" steel or alloys, it will be much easier and cheaper. As far as location, check your local wrecking yard or local craigslist. Wheels like what you're looking for can be found in either location fairly easily. They most likely won't be as pretty as you want, but at least they'll roll. Quote Link to comment
metalmonkey47 Posted March 30, 2012 Report Share Posted March 30, 2012 Find some stock S13 240sx wheels and your done. 205/60/15's are cheap to find too Quote Link to comment
HRH Posted March 30, 2012 Report Share Posted March 30, 2012 Forgot about those! Good call mm. Quote Link to comment
Abe Froman Posted March 30, 2012 Report Share Posted March 30, 2012 Find some stock S13 240sx wheels and your done. 205/60/15's are cheap to find too I dont think those will fit on the front due to offset, I know on a 510 they will hit the strut. Might be the same on the Z. How about a set of 280zx turbo wheel's. Quote Link to comment
bludestiny Posted March 30, 2012 Report Share Posted March 30, 2012 I bought a beater set of turbo swastikas for $170. I've seen them go for $150 but it may take a while to find them. You can find 14" rims all day long for $100 though Quote Link to comment
that one guy Posted March 30, 2012 Author Report Share Posted March 30, 2012 Thanks everyone for the help! And I'm quite new, so I wan't aware of the for sale/wanted section. Also, I just got my tax returns back, 400 bucks in my pocket, so I just ordered some that look decent and weren't too terribly pricey. Again, thanks! Quote Link to comment
