Lockleaf Posted March 23, 2012 Report Share Posted March 23, 2012 I don't know if any of you guys have this problem, but my weber has some age on it and started acting up recently. My main throttle shaft, to which the throttle cable attaches, now does more than rotate. It pulls/wobbles toward the secondary barrel. This has the incredibly annoying effect of causing the secondary linkage to bind up and never open. My carb runs as a single barrel no matter what because of this problem. Likely it is also allowing a bit of an air leak in my carb. There is however, a very simple repair that I was recently shown. https://www.pegasusa....asp?RecID=5949 The carb is basically made for these to slip right in and it completely supports the shaft and improves throttle rotation ability while removing wobble. Just thought I would share. I am ordering these soon. They seem to be pretty simple to install. Video of install: 1 Quote Link to comment
bryant2482 Posted March 25, 2012 Report Share Posted March 25, 2012 mine likes to stick open sometimes and then i gotta hit the pedal again to make it close Quote Link to comment
