Skib Posted February 27, 2012 Report Share Posted February 27, 2012 Hey guys I dont have manual for a Z24 datto but I need the valve adjustment clearances and the head bolt torque specs. Quote Link to comment
elfirebeasto Posted February 28, 2012 Report Share Posted February 28, 2012 I'm not sure about clearances but I think head bolts should be 60 ft lb...or that's the retighten torque. I have a manual in my truck but that doesn't help us much here given its in kansas and I'm in georgia. Its gotta be listed in the forum somewhere. Do some searching. U will probably find the answers to both ur questions Quote Link to comment
datzenmike Posted February 28, 2012 Report Share Posted February 28, 2012 Head bolts 54 to 61 ft lbs. Hot valve adjustment 0.012" for both. If replacing gasket follow this sequence... RAD 8....7 4....3 2....1 6....5 10..9 Tighten to 22 ft lbs Same sequence, tighten to 58 ft lbs. Loosen all bolts. Tighten to 22 ft lbs Same sequence, tighten to 58 ft lbs. Done. If re-torquing on an old gasket as part of a tune up. COLD ENGINE...Loosen each head bolt ONE AT A TIME in any order and tighten directly to 54-61 ft lbs. Go to next bolt. The Z24 is notorious for blowing the HG at about 100K. This is Nissan's answer for prolonging the head gasket life. The problem is the first owner my know to re-torque the head gasket every tune up, but later owners have no clue and slowly the gasket compresses and heat cycling delaminates them and... they blow. 1 Quote Link to comment
Skib Posted February 28, 2012 Author Report Share Posted February 28, 2012 Thanks Mike. The HG blew on this one and is getting replaced. Heads been to the shop, decked, pressure checked, and fresh valve job. Quote Link to comment
