spudly13 Posted February 22, 2012 Report Share Posted February 22, 2012 I Have a 71 datsun 510 with a stock l16, stock fuel pump. my most recent problem is gas coming out of the vent on the top of one dual Su at high rpms Wondering what causes it before i go taking it apart! Quote Link to comment
ggzilla Posted February 22, 2012 Report Share Posted February 22, 2012 There is only one thing that causes it -- the fuel level is incorrect. You can probably fix it by adjusting the float level, but the float also might have a hole it it. New floats are $17 from Nissan. Or it could be a partially leaking needle-and-set for the float, so inspect that carefully. They rarely go bad, but if they do it's the same one used by downdraft Hitachis. Quote Link to comment
spudly13 Posted February 22, 2012 Author Report Share Posted February 22, 2012 Sweet, ill take it apart and inspect everything then try adjusting the float level Quote Link to comment
Sealik Posted February 22, 2012 Report Share Posted February 22, 2012 They rarely go bad, but if they do it's the same one used by downdraft Hitachis. Hmmmm...good to know. Are the floats larger in the 46s? Quote Link to comment
ggzilla Posted February 22, 2012 Report Share Posted February 22, 2012 Yes, or at least they are different. They don't interchange with 38mm floats. Quote Link to comment
