slodat Posted April 17, 2007 Report Share Posted April 17, 2007 I have a perfect condition Weber 32/36DGAV-IC carb and equally nice Offenheuser dual plane intake manifold for Datsun L series 4 cylinder engines (L16, L18, L20b). I purchased the carb brand new last year for $400 from Redline. It has a working electric choke and idle cutout solenoid. The idle cutout solenoid eliminates any possibility of engine run-on after the ignition switch is turned off. It also includes the mechanical throttle linkage shaft for use in a '68-'73 Datsun 510. This is a VERY nice carb setup for your 510 or other Datsun. The jets were changed for an L20b. It comes with a small assortment of primary, secondary and air correction jets. This is on CL in Portland. I will sell for $350 to a Ratsun. Link to comment
Bulletside Posted April 18, 2007 Report Share Posted April 18, 2007 Oh man, what else would you need to slap this on a 620 ('78) ? Link to comment
slodat Posted April 18, 2007 Author Report Share Posted April 18, 2007 Nothing that I know of. Should be a bolt on affair. Link to comment
Bleach Posted April 18, 2007 Report Share Posted April 18, 2007 if your '78 620 has the factory manifolds, you'll need to switch to an older L-series exhaust manifold. When you remove your factory intake, the part where it attaches to the exhaust manifold will be open. The older exhaust manifolds don't connect together with the intake. Link to comment
slodat Posted April 18, 2007 Author Report Share Posted April 18, 2007 Thanks Bleach! I didn't know that! Link to comment
datsunaholic Posted April 18, 2007 Report Share Posted April 18, 2007 '78-79 didn't connect together either. Only the '75-77 did. I have a engine with a '78 exhaust manifold and a L16 intake on it. Link to comment
slodat Posted June 14, 2009 Author Report Share Posted June 14, 2009 It sold.. TWO years ago.. shortly after the post was made... Link to comment
Bleach Posted June 15, 2009 Report Share Posted June 15, 2009 no really, how much? :D haha Link to comment
