Z3ROT3CH Posted February 17, 2012 Report Share Posted February 17, 2012 Hi I was wondering if a long block sr20det is any different than what I have seen on here in other datsun 620 . Can't seem to find the block length to see if it will still fit thanks for any help and sorry if it is posted in wrong section . .. Z3ROT3CH .. Quote Link to comment
Lee R Posted February 17, 2012 Report Share Posted February 17, 2012 Hi I was wondering if a long block sr20det is any different than what I have seen on here in other datsun 620 . Can't seem to find the block length to see if it will still fit thanks for any help and sorry if it is posted in wrong section . .. Z3ROT3CH .. A long block is not a unit of measurement. :) Quote Link to comment
ggzilla Posted February 17, 2012 Report Share Posted February 17, 2012 Long block is the block with the cylinder head attached. SR20 for RWD comes in only one length. Not sure if the FWD version is any shorter. Quote Link to comment
Z3ROT3CH Posted February 17, 2012 Author Report Share Posted February 17, 2012 Ya the more I looked up I was starting to think that.. so it will work then ? And thanks for the reply Quote Link to comment
Z3ROT3CH Posted February 17, 2012 Author Report Share Posted February 17, 2012 Thanks for the replys I just had to ask cuz I'm arranging to buy an Sr20det long block and wanted to make sure it would fit . Quote Link to comment
Lee R Posted February 17, 2012 Report Share Posted February 17, 2012 Ya the more I looked up I was starting to think that.. so it will work then ? And thanks for the reply start here! http://www.datsunminitruckin.com/sr20det-into-a-datsun-620_topic1632.html Quote Link to comment
ggzilla Posted February 17, 2012 Report Share Posted February 17, 2012 What will work? A long block is not a complete engine. Just the block (with its internals) with head attached. Doesn't necessarily even include the oil pan. Quote Link to comment
Z3ROT3CH Posted February 17, 2012 Author Report Share Posted February 17, 2012 It's a redtop longblock with stock exhaust manifold and wire harness from a 240sx Quote Link to comment
Tristin Posted February 17, 2012 Report Share Posted February 17, 2012 Just so you know: Short block- just the block Long block- block with head It should be called "short" and "tall" but whatever. Quote Link to comment
ggzilla Posted February 17, 2012 Report Share Posted February 17, 2012 240SX didn't come with an SR20 ... maybe it has a modified wiring harness. Will it work? Depends on how complete it is. Quote Link to comment
Lee R Posted February 17, 2012 Report Share Posted February 17, 2012 If you got it out of a 240 then the PO of that 240 put it in there. Got a oic? You still need a transmission. Quote Link to comment
