screamer510 Posted February 14, 2012 Report Share Posted February 14, 2012 Hey y'all. I'm looking for a set of 4 pistons, pins, and rings for a '77 200SX L20b. Stock cast preferred. Standard bore size, 3.35". NOS or new. I'm in Georgia, ZIP 30828. Email "dandavisibo" @ "gmail" dot com Thanks Dan Link to comment
metalmonkey47 Posted February 14, 2012 Report Share Posted February 14, 2012 Dan, check out Rock Auto. You can buy a ring/piston/pin set for somewhere in the neighborhood of $35. They had some on closeout a few months back. I had a set on the side a while back but sold them. Link to comment
datzenmike Posted February 14, 2012 Report Share Posted February 14, 2012 For best results measure the bore for taper, oval or just plain worn out. The piston to bore clearance on the L20B is 0.001" to 0.0018" and that's not very much. Additionally Nissan had 3 or 4 'grades' of bore and piston sizes to allow for mass production. For best long life results, and seeing as how you are buying new pistons anyway... get a slight oversize and have your block over bored to match them. This will assure you a proper piston to bore clearance and good compression. Link to comment
