dimedude Posted January 29, 2012 Report Share Posted January 29, 2012 I'm pretty it will but not sure of what parts I would need the sr's bellhousing or the z24? What clutch and flywheel the one from the z24 or the sr Thanks for the help Greg Quote Link to comment
ggzilla Posted January 29, 2012 Report Share Posted January 29, 2012 These transmissions do not use a bellhousing. You can swap the entire front half of the tranmission case. Use the flywheel and clutch that matches the engine you will be using. Quote Link to comment
datzenmike Posted January 29, 2012 Report Share Posted January 29, 2012 Usually not good to match a newer (and presumably much stronger) engine with an older generation transmission. Try to find a C type (FS5W71C) from a 240sx or a shorter D21 5 speed. The C types are much stronger. Quote Link to comment
