priest Posted January 18, 2012 Report Share Posted January 18, 2012 What would this part number be for an L20B 2.0 OHC Distributor Oil Feed Line. So far I have had two on this vehicle, one made of Teflon and the other made from copper tubing. Neither one held the seal really well so the distributor leaked a little bit. In any case, I need to be pointed in the right direction as to where I might be able to find this part. Thanks, Steve Quote Link to comment
DISLEXICDIME Posted January 18, 2012 Report Share Posted January 18, 2012 l20b oil feed line. we need a pic of this Quote Link to comment
wayno Posted January 18, 2012 Report Share Posted January 18, 2012 Never heard of an oil feed line on an L20b, but I have heard of them on R16 and U20 roadster engines, is that what your talking about? I am not sure if the H20 had an oil feed line, but since it is basicly a R block, it could have it also. Would help to have a photo of it. Quote Link to comment
priest Posted January 18, 2012 Author Report Share Posted January 18, 2012 Totally agree with the U16 and 20 oil feed line. Those are specific to the distributor on the Roadsters. My 1600 is modified with an L20B motor, so the oil feed line is not stock to the car. This is most likely another modification with the distributor mount dissimiliar as well. I will attempt to obtain some pictures. Quote Link to comment
priest Posted January 18, 2012 Author Report Share Posted January 18, 2012 Totally agree with the R16 and 20 oil feed line. Those are specific to the distributor on the Roadsters. My 1600 is modified with an L20B motor, so the oil feed line is not stock to the car. This is most likely another modification with the distributor mount dissimiliar as well. I will attempt to obtain some pictures. Quote Link to comment
wayno Posted January 19, 2012 Report Share Posted January 19, 2012 Totally agree with the U16 and 20 oil feed line. Those are specific to the distributor on the Roadsters. My 1600 is modified with an L20B motor, so the oil feed line is not stock to the car. This is most likely another modification with the distributor mount dissimiliar as well. I will attempt to obtain some pictures. So is your tach still a mechanical tach run off the distributor? I ask As I am trying to figure out what distributor pedestal you are using/have. I am wondering what dist. you are using also. Quote Link to comment
