rsdaumer Posted January 14, 2012 Report Share Posted January 14, 2012 hey guys, trying to get the truck drivable, and ran into the common brake adjusters being froze. are the front and rear adjusters the same part? there's only the rears listed on rock auto. thanks! Quote Link to comment
pharouh Posted January 14, 2012 Report Share Posted January 14, 2012 From what I can tell they are. They're different from side to side. Threaded opposite. Quote Link to comment
datzenmike Posted January 14, 2012 Report Share Posted January 14, 2012 Heat them with a propane torch and turn the star wheel with vice grips. Spray with WD-40 when hot. They will come loose with some work. Be sure to sand down smooth and liberally use anti seize compound when assembling them. If really stuck, remove and place in a vice so you don't snap them off the backing plate. Fronts and backs are the same on the same side Quote Link to comment
