BURLEIGH Posted December 27, 2011 Report Share Posted December 27, 2011 As the Title says, I'm in need of a rear diif third member or would be willing to buy the whole assembly out of a 1981 Datsun 210 sedan or anything that will interchange and be a direct bolt in... I don't want to do any cut and pasting right now. I have plans for "bigger and better" later, but want to get the thing on the road soon. You can see my build here... http://community.ratsun.net/topic/27666-burleighs-ka-210-sedan-build/ Please email me at L28240z@yahoo.com if you have something that will work! Thanks! Richard Link to comment
datzenmike Posted December 27, 2011 Report Share Posted December 27, 2011 Doesn't the '82/'83 S110 fit the 210s? Its coil spring, disc brake and H-190. Someone here stick it into a B-210 no problems. Link to comment
80datson Posted December 28, 2011 Report Share Posted December 28, 2011 Doesn't the '82/'83 S110 fit the 210s? Its coil spring, disc brake and H-190. Someone here stick it into a B-210 no problems. Yes they do fit. Mines h165 but lookivng for the h190 Link to comment
BURLEIGH Posted December 28, 2011 Author Report Share Posted December 28, 2011 I'll take whatever I can get at this point... If you've got something that will work, I'm all ears with cash in hand! Thanks! Link to comment
BURLEIGH Posted December 28, 2011 Author Report Share Posted December 28, 2011 There's a third member on ebay that is from a '76 210... Will this work??? It looks like the same animal, but pics can be deceiving... Either way, The guy would definately have to take less than the $399 he is asking for it!!! Link to comment
ggzilla Posted December 28, 2011 Report Share Posted December 28, 2011 Yes, any of these interchange the pumpkins: 1975-1978 B210 1979-1982 B310 The 1974 B210 uses a smaller differential. It will bolt in, but is not strong enough for A14. Link to comment
BURLEIGH Posted December 30, 2011 Author Report Share Posted December 30, 2011 I found a rear diff from an 83 200SX!!!!! H190 with disks... Thanks for the tip datzenmike and 80datson! It should get here in the next week or so. I'l post up some one tire fire video in my build thread soon!!!!! :D :D :D :D :D :D :D :D :D Unless anyone knows of an LSD or locker unit available for these bad boys... :cool: Link to comment
ggzilla Posted December 31, 2011 Report Share Posted December 31, 2011 2011 Nismo catalog lists LSD for H190. Link to comment
datzenmike Posted December 31, 2011 Report Share Posted December 31, 2011 I found a rear diff from an 83 200SX!!!!! H190 with disks... Thanks for the tip datzenmike and 80datson! It should get here in the next week or so. I'l post up some one tire fire video in my build thread soon!!!!! :D :D :D :D :D :D :D :D :D Unless anyone knows of an LSD or locker unit available for these bad boys... :cool: Hopefully from an automatic.... 3.70 ratio. Five speeds were 3.545 because of the larger torque Z22E motors. Either way a good solid swap and the H-190 gears range from 3.364 to 4.875 with everything in between. No, the side gears do not need to be swapped, they are the same as all the H-190s used on the 521/620/720/D21 trucks. Link to comment
