derricklong38 Posted December 19, 2011 Report Share Posted December 19, 2011 What gear oil is best for the LSD? Runnin Circle track dont want to burn it up! P.S. anyone have any H190 parts? :lol: Quote Link to comment
Laecaon Posted December 19, 2011 Report Share Posted December 19, 2011 As long as it is not tHe 510 wagon H190, GL5 is fine. Apparently I Cant do lower Case "C" or "H" or "V" anymore... I tHink my Cat did sometHing to my keyboard... abdefgijklmnopqrstuwxyz Quote Link to comment
ggzilla Posted December 19, 2011 Report Share Posted December 19, 2011 Use 85W140 -- it can withstand high temps (hence the 140 part). Also use the kind with limited slip additive. $25 gallon Valvoline will do it. Of course for circle track racing you will also use the Nismo differential oil cooler. Quote Link to comment
derricklong38 Posted December 19, 2011 Author Report Share Posted December 19, 2011 where can i find info on the Nismo Oil cooler... took a quick around nismo.. Quote Link to comment
jesusno2 Posted December 19, 2011 Report Share Posted December 19, 2011 I just run plain ol 90w gear oil with a over the counter LSD additive in my wagon its been seeing alot of spirited daily driving works fine. Quote Link to comment
Laecaon Posted December 19, 2011 Report Share Posted December 19, 2011 I just run plain ol 90w gear oil with a over the counter LSD additive in my wagon its been seeing alot of spirited daily driving works fine. Im not sure why, but the FSM says not to run GL5 in our wagons. Not sure if the critical parts were removed when you went to LSD or not... Quote Link to comment
ggzilla Posted December 19, 2011 Report Share Posted December 19, 2011 My Datsun FSM says * GL4 for transmission * GL5 for differential The common word on Ratsun is: don't use GL5 in the gearbox presumably because of bronze transmission parts. Although some GL5 manufacturers warrant their modern GL5 for bronze parts. Quote Link to comment
Laecaon Posted December 19, 2011 Report Share Posted December 19, 2011 My Datsun FSM says * GL4 for transmission * GL5 for differential The common word on Ratsun is: don't use GL5 in the gearbox presumably because of bronze transmission parts. Although some GL5 manufacturers warrant their modern GL5 for bronze parts. Specifically the 510 Wagon... Quote Link to comment
ggzilla Posted December 19, 2011 Report Share Posted December 19, 2011 Well, there you go. thoughts: * There is no 'yellow metal' in the differential, so you can use GL5, even though they recommend GL4 for the H190 (wagon differential). But GL4 is good enough and works in the transmission too. * Perhaps the shear loads are higher in the R180 (sedan differential) so they recommend the higher spec GL5. Quote Link to comment
Laecaon Posted December 19, 2011 Report Share Posted December 19, 2011 Well, there you go. thoughts: * There is no 'yellow metal' in the differential, so you can use GL5, even though they recommend GL4 for the H190 (wagon differential). But GL4 is good enough and works in the transmission too. * Perhaps the shear loads are higher in the R180 (sedan differential) so they recommend the higher spec GL5. Thanks to Mike Klotz and something I remember he posted about the early diffs. Sure enough there are some copper or bronze parts in the 510 wagon. Looks like a thrust washer on the side gears. GL5 contains about 59% more sulphur additives that while protecting the steel gear teeth will corrode the copper or 'yellow metal' in transmissions and now... the 510 goon H-190. Here is an even earlier 320 H-190 diff... . Thanks 69dime this I did not know about until you made me re-think it. GL-4 it is for the stock goon diff. Quote Link to comment
ggzilla Posted December 19, 2011 Report Share Posted December 19, 2011 now it is clear. Thanks. Quote Link to comment
