VintageRice Posted December 16, 2011 Report Share Posted December 16, 2011 My factory windshield seal (front and rear) look pretty good overall, except the corners are brittle to the point of falling apart and cracking. I was thinking of ways to fix, or at least make them look better. Came up with this. "Plasti Dip" It's for dipping your tool handles in. I got black of corse. I'm going to try paining some of this onto the corners to fill the cracks, then maybe sand a little to blend it in with the rest of the seal. I'll let you all know how it turns out. :) Quote Link to comment
KC Phirus Posted December 16, 2011 Report Share Posted December 16, 2011 Yeah man do it! I got a can in the garage :D Quote Link to comment
Guest kamakazi620 Posted December 16, 2011 Report Share Posted December 16, 2011 I use Black RTV works like a dream After its dry use a razor blade to trim it Quote Link to comment
MikeRL411 Posted December 16, 2011 Report Share Posted December 16, 2011 I'm repeating this from some time ago. Trim the brittle corner sections at a 45 degree angle to the windshield with a sharp single edge razor blade or Xacto type knife. Scrape the glass as clean as you can. Go as far up the sides as looks cruddy to insure that you will seal all the leak paths. Wet a rag with white vinegar and scrub the glass and the sound surface of the existing rubber seal. This both cleans the glass and primes the rubber to insure a good bond. Use black RTV no silicone, it outgasses acetic acid [vinegar] as it cures and will bond well to the primed rubber seal. Smooth with a wet finger or any old piece [wet] of sheet plastic and it will look as good as new. I use the junk "try my credit card" mailers. Probably better looking than the rest of the seal. As above, trim carefully with a razor blade or hobby knife to clean over load on the glass. Quote Link to comment
MikeRL411 Posted December 16, 2011 Report Share Posted December 16, 2011 Sorry for the double post. Quote Link to comment
VintageRice Posted December 17, 2011 Author Report Share Posted December 17, 2011 I love ratsun. There's always a "cheapo way" LOVE IT!! Quote Link to comment
ZackTheImpaler Posted December 27, 2011 Report Share Posted December 27, 2011 I'm going to have to give this a shot on my 411..seems logical and like it would give me a good looking finished product. I'm repeating this from some time ago. Trim the brittle corner sections at a 45 degree angle to the windshield with a sharp single edge razor blade or Xacto type knife. Scrape the glass as clean as you can. Go as far up the sides as looks cruddy to insure that you will seal all the leak paths. Wet a rag with white vinegar and scrub the glass and the sound surface of the existing rubber seal. This both cleans the glass and primes the rubber to insure a good bond. Use black RTV no silicone, it outgasses acetic acid [vinegar] as it cures and will bond well to the primed rubber seal. Smooth with a wet finger or any old piece [wet] of sheet plastic and it will look as good as new. I use the junk "try my credit card" mailers. Probably better looking than the rest of the seal. As above, trim carefully with a razor blade or hobby knife to clean over load on the glass. Quote Link to comment
