yello620 Posted December 13, 2011 Report Share Posted December 13, 2011 This is what I did. I used the accessories as the battery, the alternator as the trigger. This is just a temp solution... Till i can throw in a new oil pressure switch. I also now know how to bypass it altogether if i get stuck on the side of the road... So, this is my temp fix. Now that is much better than cutting up a good harness. Completely reversible and just waiting for the proper fix to the problem. Way to go Izzo. :D Quote Link to comment
izzo Posted December 13, 2011 Author Report Share Posted December 13, 2011 Now that is much better than cutting up a good harness. Completely reversible and just waiting for the proper fix to the problem. Way to go Izzo. :D lol thanks Jason, my goal was never to cut the original harness. Just needed the diagram to figure out how to wire the bosch relay in. What I didn't realize is that power came from most of the wires. That shit trips me out.. I can see why they have a special relay for that fuel pump cut off now. It is a safety feature, but sucks when something goes haywire. At least now I have a backup and wont get stranded again after i replace the oil unit - if it the oil pressure switch isn't the cause. Quote Link to comment
dreadsiren Posted April 29, 2012 Report Share Posted April 29, 2012 not to drag out an old thread, but did you ever find the real problem? I'm chasing the same deamon in my 84... keep getting redirected to the fuel pump relay but it isnt bad (tested, swapped, tested... etc) symptoms exactly the same! if you figured it out I would love to know!! and if your still running your temp fix has it worked fairly well? if so I'll just rigg up like you did :) Quote Link to comment
izzo Posted November 29, 2012 Author Report Share Posted November 29, 2012 not to drag out an old thread, but did you ever find the real problem? I'm chasing the same deamon in my 84... keep getting redirected to the fuel pump relay but it isnt bad (tested, swapped, tested... etc) symptoms exactly the same! if you figured it out I would love to know!! and if your still running your temp fix has it worked fairly well? if so I'll just rigg up like you did :) Never did track it down, truck is sold and gone to another part of oregon, but he is still driving it just like it is today. Quote Link to comment
