philcas1987 Posted December 1, 2011 Report Share Posted December 1, 2011 I think I spent $50 for new Thailand door seals. Figured not alot of direct sun light on those. Might take awhile to wear out. yup all 4 doors right? thats what i have on my 510 Quote Link to comment
afbrian13 Posted December 26, 2011 Report Share Posted December 26, 2011 I have a 76 280, looks like i'm headed for the junk yard. Mine has the seal in the chassis side (not the door) already, so that look perfect for me! All my rubber on the doors is shot. Thanks! Ever come up with something for inside the window channel on the door? Quote Link to comment
VintageRice Posted December 26, 2011 Author Report Share Posted December 26, 2011 Nothing yet for inner squeegies. Still looking. Quote Link to comment
thetimanator Posted December 27, 2011 Report Share Posted December 27, 2011 after reading this, I'm gonna go to the junkyard tomorrow! Quote Link to comment
Drakoe1 Posted December 27, 2011 Report Share Posted December 27, 2011 This is awesome, definitely gotta make it out to the pnp now Quote Link to comment
darc510 Posted December 27, 2011 Report Share Posted December 27, 2011 Started looking for some window squeegies that could be modified and attached to thte stock 510 trim piece. Found a set that looked promising off a older ford/murcury. Yanked them. Ended with this. this turned out great! What era are we talking about here? some of the fords i looked at (mainly 90s) have that C shaped/clamp style door squeegees...i might have to dig further into history. I have three yards that surround me that kinda carry different amounts of one age and import/domestic than the other ones (makes it easier to know that you only have to go to one yard if you are searching for something). but yeah, should the 70s-80s big box boat cars be what i'm looking for? Quote Link to comment
VintageRice Posted December 27, 2011 Author Report Share Posted December 27, 2011 I wanna say it was a late 80's early 90's car. I wish I would have paid closer attention but I took squeegies off like ten cars when I was there sorted through them at the end so got kina confusing. I know the car was in the ford/merc section, but that's all I'm sure of. Next trip to PnP I'll look around. I found the same ones, only shorter, (probably too short) on a mazda truck and that was also that era vehicle. Quote Link to comment
VintageRice Posted January 2, 2012 Author Report Share Posted January 2, 2012 The squeegees came off a ford probe. Just got back from PnP. Quote Link to comment
thetimanator Posted January 2, 2012 Report Share Posted January 2, 2012 The squeegees came off a ford probe. Just got back from PnP. 89-92 or 93-97? I found an early 90's eclipse a few days ago and pulled the door seals. Seems to work well. I put the door sills in, trimmed it a little and and left the bottom part of the original door seal on for now. Not sure what I'm going to do about the back doors though.. Quote Link to comment
VintageRice Posted January 2, 2012 Author Report Share Posted January 2, 2012 89-92 or 93-97? I found an early 90's eclipse a few days ago and pulled the door seals. Seems to work well. I put the door sills in, trimmed it a little and and left the bottom part of the original door seal on for now. Not sure what I'm going to do about the back doors though.. DAMMIT ! Ok, I got this..........hold on. Quote Link to comment
VintageRice Posted January 2, 2012 Author Report Share Posted January 2, 2012 Ok, checked their online inventory and they show only one there, it was off a 1993. The squeegies I found yesterday, the black paint was flaking off the seal, and there was chrome under it. Mine were all rubber coated. So I'm not sure if theres still another ford car with the same type of trim, or just a different year/package had the rubber coated stuff. OR maybe this probe was just is worse shape IDK. Wither way, now you guys know what to hunt for and what the seal looks like. Just go to your local yard and start plucking seals. All you need is a flat head screw driver to start plucking them off. Just start with this profile. And trim the little flap off to look like this. then the trimmed side faces the window, and the metal "7" shaped part hugs the factory trim piece. Wha-LA! Quote Link to comment
thetimanator Posted January 2, 2012 Report Share Posted January 2, 2012 just got back from pull-a-part. got two more 1990 eclipse door seals hopefully enough door felt to do all 4 windows (out of an 85 720 and late 80's isuzu trooper) also two inner squeegees off the 720 which I'm hoping will work with some trimming All for less $6 unfortunately no decent late model probes and I'm still on the look out for something for the trunk Quote Link to comment
5NDIME Posted January 10, 2012 Report Share Posted January 10, 2012 Those door seals do look BMW-like. Look for late 80s e30 (3 series) and early 80s e28 (5 series). I have owned a few of both of those cars and those seals look very similar. Also similar to 240D and 300D MBs which come in wonderful colors like turd brown. Also the squeegies look like they could be off the same cars as well. Look for 2 door e30s since the doors are longer, better chance to fit in one clean run. e30 sedan window length may not even be as long as PL510 2 door windows based on my best guess. Quote Link to comment
darc510 Posted January 10, 2012 Report Share Posted January 10, 2012 so with the hood E30 rubber, did you trim it down some (on the bottom) in order for the hood to close properly? I imagine that you had to...my hood bows a little bit in the middle... Just checking. Also, tried to use a 90s Sentra trunk rubber... Not gonna work, it's a bit thick (that's what she said) and you would need an additional 14" to complete the loop. Prob gonna hit the yard tomorrow to find something more 'usable'. Quote Link to comment
erichwaslike Posted January 10, 2012 Report Share Posted January 10, 2012 Well hot damn, those POS's are good for something after all... :blink: :lol: pos? awd turbo 5speed cars that spank? my buddys had a few. hes parting 2 out right now so ima go steal his door rubber! Quote Link to comment
jay123 Posted November 12, 2013 Report Share Posted November 12, 2013 Picked up my door seals from an Eclipse as stated above yesterday. My '72 2dr 510 came with no rear window rubber/seals at all.. NOTHING.. I don't even know what to look for or what they look like. Can someone snap some pics of the rear window seals around the window frame and window opening? Perhaps I can match it up with something at the PnP, unless someone has already done it and can share what it came off. Thanx in advance.. Quote Link to comment
MARS 510 Posted November 21, 2013 Report Share Posted November 21, 2013 I just read this thread, and that's some good info you guys put out here. My door seals are gone and it's starting to rain here so I'm goanna be going to PNP over the weekend and look for some door seals. Thanks. Quote Link to comment
