Siqx20 Posted November 21, 2011 Author Report Share Posted November 21, 2011 Everything is already removed. This last bolt is the only thing holding it all on. Quote Link to comment
paradoxx Posted November 21, 2011 Report Share Posted November 21, 2011 a torch, heat until water can evap and slamit! This way i removed a siezed brake caliper piston from the yz, something completely different but kept the seals unmelted. Quote Link to comment
Siqx20 Posted November 21, 2011 Author Report Share Posted November 21, 2011 I heated it, I beat it, I screamed the fuck at it. Then I said fuck it and went to town with the cutting wheel. BRANDON- 1 DATSUN - 0 Quote Link to comment
DailyDato Posted November 22, 2011 Report Share Posted November 22, 2011 Glad to see you got it off, I had the same problem on my 720.....when i bagged mine......um What OD wheel you plannin on runnin, cause i can answer you alot of questions, bigger than 17s, even with drop spindles, you will have issues if your not careful, the UCA will hit your bag bracket, n you wont get enough lift or drop unless you cut a pocket and reccess your bags back into the frame rail, 8in OD pipe works great, oh, and plan to build Custom lower A arms unless you like bending your tension rods and not steering, lemme know if i can help. i should have some pics somewhere too if it will help Quote Link to comment
Siqx20 Posted November 22, 2011 Author Report Share Posted November 22, 2011 Yeah I will be cutting out part of the frame to fit the bag in there. Im going ti z the frame 3 inches cause I have heard if ppls running into problems with the lower control arm hitting the frame before it lays. Im going to be running 18's. I think my z'ing the frame u will solve alot of the clearance issues with the lower control arms. Not sure what im going to do about steering. I might swap in a rack and pinion . Been searching around trying to find info if anyone has swapped one into a 620 before. Quote Link to comment
DailyDato Posted November 24, 2011 Report Share Posted November 24, 2011 With selective and creative cutting, you can get it to lay 18s without the"z", you need the construct what is known as a tension rod delete, and then the rest is just cuting till it lays, it will create a mounting point behiond the LCA to a bushing, creating an A arm instead of a stablizer arm, I have the bushings, 2 1/2 drop spindles, and plenty of bags, Dominator RE5s an 6s, tanks, valves if your interested, i even have some 7in pipe to build bag cups into the frame with, no compresssors, but will to seperate, lemme know. Quote Link to comment
Siqx20 Posted November 24, 2011 Author Report Share Posted November 24, 2011 Didn't know they made drop spindles for 620's.... and yeah im very interested in some of that stuff. Pm me some prices and we can make a deal. Cause I was actually place mingled on buying up alot of that stuff here soon. And I always like dealing with fellow ratsuners. Quote Link to comment
Siqx20 Posted November 24, 2011 Author Report Share Posted November 24, 2011 Also interested in this tension rod delete your talking about. So if u have any info or pics I would love to seem thanks. :) Quote Link to comment
