78silvia200sx Posted November 5, 2011 Report Share Posted November 5, 2011 on my 78 200sx my right turn signals work perfect but my left ones dont flash but stay on i just replaced all bulbs left & right on front & back but when i turn the emergency flashers on they all work but the front left isnt as bright as the right front its really starting to bug me i was thinking it might be the flasher unit but the right side works and they all work with the 4 ways on... is there differant flashers for left/right/4ways cause someone just told me there might be 3 for the differant ways it flashes? any help please? Quote Link to comment
datzenmike Posted November 5, 2011 Report Share Posted November 5, 2011 Front left signal is the problem.There is possible corrosion in the +12 volt side. I would say possibly the ground side but then the running light would also be dim and you don't mention this. This could even be the bulb socket which gets it's share of road spray. Look into the bottom of the socket for corrosion and be sure the two contacts are still spring loaded to make firm contact with the bulb. Check the nearest connector, sometimes just unplugging and plugging back in will fix it. Check that you have the proper bulb and that it is in correctly and not turned 180 and the running light is not in the signal light position. Quote Link to comment
78silvia200sx Posted November 5, 2011 Author Report Share Posted November 5, 2011 Front left signal is the problem.There is possible corrosion in the +12 volt side. I would say possibly the ground side but then the running light would also be dim and you don't mention this. This could even be the bulb socket which gets it's share of road spray. Look into the bottom of the socket for corrosion and be sure the two contacts are still spring loaded to make firm contact with the bulb. Check the nearest connector, sometimes just unplugging and plugging back in will fix it. Check that you have the proper bulb and that it is in correctly and not turned 180 and the running light is not in the signal light position. ok with the running lights on the right side is still fine and on the left side the rear stays solid and the front isnt on at all when i use the turn signals so i would clean up the socket but i cant find my damn turminal connection cleaner Quote Link to comment
datsunaholic Posted November 5, 2011 Report Share Posted November 5, 2011 Also could be the wrong type of bulb. Or a broken ground. But cleaning the socket would be step #1. Quote Link to comment
78silvia200sx Posted November 5, 2011 Author Report Share Posted November 5, 2011 so i fixed the problem it was corrosion on the connector and on the bulb socket i just took a brillo pad and scuffed up both connections now they work perfect Quote Link to comment
