wildbill1 Posted October 8, 2011 Report Share Posted October 8, 2011 How do I adjust the idle on my '86 King Cab ST 2.4L gas carb? Quote Link to comment
izzo Posted October 9, 2011 Report Share Posted October 9, 2011 there is a screw near the throttle cable, or on the same assembly. you can loosen/tighten and adjust to your liking. if you are trying to get the throttle lower, and it wont. adjust the throttle cable to give it a little more slack. Quote Link to comment
datzenmike Posted October 9, 2011 Report Share Posted October 9, 2011 This is not the exact carb you have but the idle speed screw is just to the left of the large vertical spring in this picture. Your screw will likely be a Phillips head. What has happened that you need to adjust the idle? By any chance is it idling too fast??? . Quote Link to comment
