Gary Posted October 1, 2011 Report Share Posted October 1, 2011 ive got a 620 which came with a J15, points ignition and an external reg alternator. now it has an L with an internal reg alternator and electronic ignition ive got some weird problems and while i doubt this thing would be a part of it, just wondering what it is and if its necessary its wired from an IGN/ACC source to negative i think Quote Link to comment
Farmer Joe Posted October 1, 2011 Report Share Posted October 1, 2011 is that the capacitor? maybe a little deal to cut down radio noise? 1 Quote Link to comment
Gary Posted October 2, 2011 Author Report Share Posted October 2, 2011 dunno, if i bypass it the wire heats up when switched to ACC so if its not important it'll have to be disconnected entirely. ill leave it off see how it goes Quote Link to comment
datzenmike Posted October 2, 2011 Report Share Posted October 2, 2011 Do not bypass a capacitor. That's a direct short. Just remove if in doubt. Quote Link to comment
Gary Posted October 2, 2011 Author Report Share Posted October 2, 2011 sweet why would there be a cap between negative and a switched positive? its a black/red wire that comes off the ignition switch Quote Link to comment
datzenmike Posted October 2, 2011 Report Share Posted October 2, 2011 I think even the electronic ignitions have them too. When points open or the EI module suddenly looses it's ground through the coil the 12 volts doesn't just stop suddenly, there is always some high frequency sinusoidal 'ringing' produced, sort of like an echo. This echo, for want of a better word, ends up on the radio as a ticking sound that increases with engine revs. A capacitor will conduct an alternating current but not direct current. The capacitor will allow this high frequency alternating signal a path to ground and dampen it faster. This is an extremely simplified answer. Just imagine the square wave form below as the voltage applied to the coil in an on off on off signal. Note the 'noise' component? The capacitor will 'filter' that out. 1 Quote Link to comment
Gary Posted October 2, 2011 Author Report Share Posted October 2, 2011 cool, i just found a spare that looks in better condition so ill keep it for now thanks mike :) Quote Link to comment
