PHXDatsun Posted September 24, 2011 Report Share Posted September 24, 2011 Has anyone used longer shocks on the rear after lowering to allow more travel if so what kind? or will it be fine with stock shocks? I got 3inch blocks. Quote Link to comment
Wide14u Posted September 24, 2011 Report Share Posted September 24, 2011 do you mean shorty shocks Quote Link to comment
PHXDatsun Posted September 24, 2011 Author Report Share Posted September 24, 2011 well i know you need shorter shocks in the front but the back seems to need longer shocks since they are pulled almost all the way out or should they be fine like that? Quote Link to comment
Wide14u Posted September 24, 2011 Report Share Posted September 24, 2011 you should be fine with only a 3 inch drop Quote Link to comment
PHXDatsun Posted September 24, 2011 Author Report Share Posted September 24, 2011 cool thanks man Quote Link to comment
rockstar 620 Posted September 25, 2011 Report Share Posted September 25, 2011 i think u retain the same shock travel in the rear when u put blocks in...cuz the mount stays in the same place the only thing ur doing with the blocks is bring the diff up. Quote Link to comment
justin 620 Posted September 25, 2011 Report Share Posted September 25, 2011 i think u retain the same shock travel in the rear when u put blocks in...cuz the mount stays in the same place the only thing ur doing with the blocks is bring the diff up. You are correct. It took me hours to explain that to my dad, ha. Quote Link to comment
