H5WAGON Posted December 2, 2011 Author Report Share Posted December 2, 2011 So the car is running and driving.:rolleyes: Just some other points to mention on the computer install. I used another Blue Nissan relay to power up the computer, hooking it to the "Power On" wire, with the other relays for the motor harness. Which supplies power to these points: #29 & #30 are both GRN/BLU spliced together and go to the inhibitor harness plug #28 RED/BLK I think I used a 10amp fuse before the relay on this. This transmission will operate without the computer powered on, but you can tell it wants input from the motor. More responsive when turned on. #7.....The kickdown wired up....Ground = ON LT BLU wire. Need to find a good Push Button switch that lights up for the O/D, or mount a indicator light. But the plan is to find a small one to put on the right side of the ash tray. That one is #9 GRN/RED again Ground = ON I will also be adding the cruise control soon.:D 1 Quote Link to comment
darrel Posted December 16, 2011 Report Share Posted December 16, 2011 n/m, just read your build thread. great job! 1 Quote Link to comment
H5WAGON Posted December 18, 2011 Author Report Share Posted December 18, 2011 Thanks! You saw the build thread in Project Datto? http://community.rat...rneywroad-trip/ What were you wondering about? 1 Quote Link to comment
