frodo70444 Posted September 22, 2011 Report Share Posted September 22, 2011 ok i am going to replace the clutch master cylinder on my 210 and i just want to make sure i got my ducks in a row before i get to excited. all i should have to do is unhook the line from it take the two nuts off from the firewall and pull the pin out of the pedal to remove the old one right? Quote Link to comment
bananahamuck Posted September 22, 2011 Report Share Posted September 22, 2011 Yes..........but, bench bleed the new master before you take apart anything. Quote Link to comment
frodo70444 Posted September 22, 2011 Author Report Share Posted September 22, 2011 i just ordered the new master cylinder tonight so it isn't here yet but what do you mean bench bleed? Quote Link to comment
bananahamuck Posted September 22, 2011 Report Share Posted September 22, 2011 Was looking for short video .......I didn`t think you would be back so fast.. Video doesn`t show it but clamp master in a vise ((( CAREFULLY ))) to make it easier to manage. and you could get old brake lines from another car at junkyard and some hose from hardware if you cant find the kit he mentions...OR if your a cheep bastard like me Quote Link to comment
frodo70444 Posted September 22, 2011 Author Report Share Posted September 22, 2011 umm im so cheap my mom bought the parts for me cause i can't afford them i have 0 dollars and to be honest i dont have old brake lines either..why couldnt i just install it and pump the dirn pedal until fluid comes out then hook the hose up and bleed the system as a whole? Quote Link to comment
bananahamuck Posted September 22, 2011 Report Share Posted September 22, 2011 Well if you tighten line tight then crack them a tiny bit so there is at least some pressure built up ...it will just take a lot more pumping And sometimes the pedal never stops feeling kinda mushy.. But ya gotta do what ya gotta do. Quote Link to comment
frodo70444 Posted September 22, 2011 Author Report Share Posted September 22, 2011 ok so your saying i can put the line on and have someone pump and crack it open off and on until fluid comes out? i dont mind making my brother pump it a few hundred extra times. Quote Link to comment
Big Schlink Posted September 22, 2011 Report Share Posted September 22, 2011 8 bones SAE: http://www.autozone....fier=226332_0_0_ 5 bones metric: http://www.autozone.com/autozone/accessories/Help-Universal-metric-master-cylinder-bleeder-kit/_/N-25ko?itemIdentifier=102947&_requestid=2091218 Quote Link to comment
