hz in az Posted September 21, 2011 Report Share Posted September 21, 2011 I have a 64 L320 that i dropped a J13 into from i believe a 60's 520. I have the stock drive shaft that came with the E1 and 3 on the tree on the 1200cc motor. they seem to be the same length but the splines don't match up. Is the an easy fix? Do I need a J13 drive shaft off a 520? thx, HZ Quote Link to comment
wayno Posted September 21, 2011 Report Share Posted September 21, 2011 I have a 64 L320 that i dropped a J13 into from i believe a 60's 520. I have the stock drive shaft that came with the E1 and 3 on the tree on the 1200cc motor. they seem to be the same length but the splines don't match up. Is the an easy fix? Do I need a J13 drive shaft off a 520? thx, HZ Are the trannys the same lenth? Your going to need the other transmission yoke, hopefully the u-joints are the same so you can just put the yoke you need onto the L320 driveshaft. You also might be able to connect the column shift tranny to the J13 engine, BTW, the 3 speed on the tree tranny is more than likely a 4 on the tree, as I have never heard of a datsun 3 on the tree. Quote Link to comment
ggzilla Posted September 21, 2011 Report Share Posted September 21, 2011 A lot of Datsuns had 3-speed column shift. Some 410s had 3-speed column (remote) shift. Quote Link to comment
wayno Posted September 21, 2011 Report Share Posted September 21, 2011 A lot of Datsuns had 3-speed column shift. Some 410s had 3-speed column (remote) shift. I did not know this. What about the L320, did it come with a 3 speed column shift? If I had not bought Mikes NL320, I would have thought they were 3 speeds, until I got one running and tried to find reverse, as reverse is not as simple to find as a three on the tree in an american vehicle. My first car was a 3 speed on the column, it was a 63 rambler classic, so was my second car, I am very happy that I didn't decide to collect them. :lol: Quote Link to comment
hz in az Posted September 21, 2011 Author Report Share Posted September 21, 2011 Are the trannys the same lenth? Your going to need the other transmission yoke, hopefully the u-joints are the same so you can just put the yoke you need onto the L320 driveshaft. You also might be able to connect the column shift tranny to the J13 engine, BTW, the 3 speed on the tree tranny is more than likely a 4 on the tree, as I have never heard of a datsun 3 on the tree. I am not sure about the length the L320 didn't come with motor or tranny. Sounds like a plan. Any Idea on where to find a 520 yoke? thx Quote Link to comment
wayno Posted September 21, 2011 Report Share Posted September 21, 2011 I am not sure about the length the L320 didn't come with motor or tranny. Sounds like a plan. Any Idea on where to find a 520 yoke? thx I beleave that the wrecking yards are the place to look, or put a wanted ad in this forum. It would be best to take a clear photo of the tailshaft teeth, to be sure you buy what you need, these datsun years had a lot of changes, when advertizing, be sure to have the tooth count needed with a photo. Datzenmike might know what years have the yoke you need. Quote Link to comment
