Radiant-Designer Posted September 14, 2011 Report Share Posted September 14, 2011 Well thank you all for all the help and opinions. I thought I would share some updated pics and some of the improvments that I have made..... first off the Weber upgrade. this took some time and patients, but overall had a good sense of accomplishment (and it cleaned up the engine bay a lot now that I took out all the California smog stuff)! I purchased it from Weber Carbs direct, the instructions were a bit lacking (it was a very general set that I assume are used for most any install and had the wron info for the studs and the adaptor plates, and then talked about lines that I didnt have) It is a lot more fun to drive with more "get up and go" and a smoother accelleration and over all drivability. It could use a little tweaking, but it will come with time. Quote Link to comment
Radiant-Designer Posted September 14, 2011 Author Report Share Posted September 14, 2011 PS that above picture shows the fuel pressure regulator and the gauge that I put on there to make sure I was getting the right pressure when I was installing and testing the Carb, It is being cleaned up and made to look nicer now. Quote Link to comment
Radiant-Designer Posted September 14, 2011 Author Report Share Posted September 14, 2011 Here are two pics of the seats that I changed out. the original was beyond worn and riding on the floor. If anyone is interested in it Its up for grabs.... hate to throw it away but I wont be using it, if nobody wants it I may just take the seat bracket. these are Corbeau racing seats, grab ya and feel nice.... kind of a pain to ge3t in and out of the truck too much but for my commute they are fine. They have seat brackets that bold right in so no modification to the truck itself (YAY I dont have to drill holes int he floor) Quote Link to comment
Radiant-Designer Posted September 14, 2011 Author Report Share Posted September 14, 2011 Put a little bit of polishing compound on it and WOW that 34 yr old paint still has some luster to it, hidden deep down inside... this shows the left (before) and the right (after) Quote Link to comment
Radiant-Designer Posted September 14, 2011 Author Report Share Posted September 14, 2011 Perhaps the best upgrade I could do... Somethign I know you have all been begging for.... Still have to install them.... but yes CUP HOLDERS Also I dont have pics of it, but I took the whole bed off (wow the gas tank is attached to the Bed and not the frame.... wtf), and used POR-15 on all of the frame that I could. I was shocked how nice it was to begin with, but it isnt in Cali anymore and New England salt and snow is notorious. Quote Link to comment
Wide14u Posted September 14, 2011 Report Share Posted September 14, 2011 the paint is going to look good Quote Link to comment
crackerjack69 Posted September 14, 2011 Report Share Posted September 14, 2011 Perhaps the best upgrade I could do... Somethign I know you have all been begging for.... Still have to install them.... but yes CUP HOLDERS Also I dont have pics of it, but I took the whole bed off (wow the gas tank is attached to the Bed and not the frame.... wtf), and used POR-15 on all of the frame that I could. I was shocked how nice it was to begin with, but it isnt in Cali anymore and New England salt and snow is notorious. Neat, I have those same cup holders in my 620. Quote Link to comment
izzo Posted September 14, 2011 Report Share Posted September 14, 2011 dodge neon center console is kinda the shit too! I need to gather up a shifter boot out of a neon and it'd be better, all in time tho. Quote Link to comment
Radiant-Designer Posted September 20, 2011 Author Report Share Posted September 20, 2011 Ok so decided to put in the 180 degree thermostat this weekend... and low and behold there wasnt even one on originally. Of course there was one of those universal gaskets in the kit that was supposed to fit all the cars, but it didnt work so well for mine. I scraped all the liquid gasket off and wire brushed the thermostat housing as clean as I could, but it leaked. 63 cents later at Napa and I got a real gasket that seems to be doing a lot better, still a little tiny leak but I am working on that. While I was working on this I noticed the bottom half of the thermostat housing, ont he pass side where the longer bolt goes in someone cracked the side of the hosing off... so the threads only go around 60% of the bolt. I'm not too worried right this second but its another thing on my replace list. just have to find one. Quote Link to comment
