skyknight789990 Posted September 12, 2011 Report Share Posted September 12, 2011 ok i want to bag my king cab an was wondering if i could use a one piece drive line i was planning on going to one went through 2 carrier bearings already i plane on getting my truck to lay frame an body right now i am using 14s with a 70 tire so its almost stock any ideas or suggestions would be great thanks damon Quote Link to comment
Wide14u Posted September 12, 2011 Report Share Posted September 12, 2011 i would try to keep it 2 peace so its easy to replace it Quote Link to comment
skyknight789990 Posted September 16, 2011 Author Report Share Posted September 16, 2011 i would like to go to a one piece cuz its gettin spendy replacing bearings an i dont want to every few months its a daily driver right now Quote Link to comment
DISLEXICDIME Posted September 16, 2011 Report Share Posted September 16, 2011 you should fix it right so your not spending money on bearings. get angled lowering blocks and/ or make a spacer to rais the carrier bearing. Quote Link to comment
skyknight789990 Posted September 16, 2011 Author Report Share Posted September 16, 2011 would that work if its bagged though i do plan on driving at normal an dragging Quote Link to comment
DISLEXICDIME Posted September 16, 2011 Report Share Posted September 16, 2011 u joints in a bagged truck where no matter what you do. if the pinion angle is off its going to wear your u joint. and datsun's require the pinion at 3 degrees if i remember right . mine dont wear out as fast since i raised the carrier and used angled blocks. Quote Link to comment
skyknight789990 Posted September 16, 2011 Author Report Share Posted September 16, 2011 i know that but if i use the bearing with a bagged truck i plan on using a 3 or 4 link maybe even a watts link set up you set the angle you want but the travel is what i am wondering about with the torque...trying to plan ahead if it would be simpler to use a one piece drive line Quote Link to comment
